- Flat towing a 5 speed Civic Hybrid?
- rough idle now won't start
- Location of O2 sensor
- Timing belt change-what else should be done? SUCCESS
- 01 trans question
- Honda Civic 2001 halts while driving
- Starter, Ignition, or Wiring problem?
- 01 honda civic lx runs for a sec then shuts down
- Manual Trans, hard to get into first and reverse.
- Possible fuel pump issue?
- Civic will not Start - Suspected electrical problem
- airbag light/code
- Car won't start
- Civic 03 overheating - confirmed HG issue ..
- Head Gasket?
- Is This a Worthy Project ?
- Check engine light after fuel pump repair
- Tranny clunks when put in drive
- Multiple codes 336, 300, 301, 302, 303 and 304
- Constant source of air in cooling system
- 05 civic gas mileage/ performance issues
- poping out of gear
- Valve Cover Grommet install w/o removing VC
- No Start No Crank Issue
- Bucking, flickering, pulsating
- Torqueing bolts in the cold
- Danger of having the timing belt done late
- Honda Civic 2001 - Power Steering Fluid
- manual transmission rebuild
- Need ideas for my 05' civic I just bought
- Please Help!
- Changed timing belt and bad MPG
- scratched cylinder head
- Overheating even in negative temps
- I think I ordered the wrong sensor >_<
- Need help asap please
- Need some advice on if i should replace the rear main seal on my civic!
- help needed, slid to curb, what did i break this time?
- starts ok in brutal cold warm up, then 2nd start cranks but no start
- 2001 ex automatic shift console
- 03 civic si - CEL code p1259 revs limited at 4k
- When to change the Head Gasket?
- Power Steering problem
- car won't pump fuel
- Another seat rock fix thread, my experience...
- Help! Oil Pan Leak
- 7th generation fuel line feeder
- 03 civic ex o2 sensor
- 02 civic front brake
- screeking noise wheel?
- Rolled head when taking to machine shop
- CEL- P0740 Won't go away!!! Help!
- 2005 Civic interior door cover
- 2005 Civic Door Locks
- CEL/numerous codes help
- i need help bad
- Front Lower Control Arm Bushings Replacement
- Scoring on head from cam shaft journals
- New Alternator is litterally smoking my wire harness!
- Hesitation & struggles up hill !
- Ugh! Coolant Disappearing :(
- strange noise from the front suspension
- P0135 won't go away
- Hearing this noise from inside of the car
- Loud noise under heavy snow/rain
- 2003 Honda Civic GX Heavy Vibration at Idle
- 02' EX Lower control arm installation problem!
- Intermittent startup and grinding at times
- 2003 EX: Idling around 2k
- gas tank is leaking from the hose that connects to it
- I drove around with a bad gas cap for 6 months...
- honda civic 2003 will not start
- Radiator Support and Other Issues
- 05 EX SE antifreeze/coolant leak - solution provided in link
- new battery was smoking and smelling horrible
- Is my civic worth it?!?
- front shock top mount "Strut Tower/Bracket" Failing
- CEL flashes randomly 04 ex with k20a2 swap
- Alternator Tension Bolt Sheared Off
- 04 Honda won't start after trying remote starter
- heating/antifreeze problem - confused
- Blow out and hit the curb
- Bought a salvage title. need help.
- just replaced axle, 01 civic ex
- My friends car is missing an EGR Valve
- Do I need to buy a new alternator for THIS piece?
- 2002 Civic Si AC Compressor
- Security wont let me start my car!
- Brake to shift Interlock
- radiator, coolant, engine light
- Bad alternator....?
- New Alternator and Battery...Car still having problems
- I am having a weird smell, just had a lot of work done
- Weird heater / temp issues
- White steam from the radiator cap
- Airbag Dash Light on-Why?
- 01 civic hard to start and flooding
- Changed starter and nothing? Now what?
- 02 Automatic Transmission Rebuild Kit -- Can't find TCI Kit
- transmission issue here we go again ut oh
- 01 Has rough idle when cold.
- Gears grinding while shifting
- Mystery wire plug?
- 01 EX oil leak
- Honda Civic 2004 / Radiator Fan problem
- Daytime Running lights not working anymore.
- Gearbox noise on deceleration only in gears 5, 4, and 3
- Quick Battery Question
- LX EX are the two transmission
- Balljoint replacement, 2002 EX
- Noise that sounds like a horse galloping.
- Unable to pinpoint suspension noises. Please help.
- Changing Timing Belt With Low Mileage
- 5 codes in one day! Please help!
- Can-muffler brand Catalytic converter
- Parasitic Draw
- Bad ECU or other?
- Honda Civic 2001 difficult to start when engine is warmed up
- alternator mounting bracket
- Can DOT4 be used as clutch fluid?
- A/C belt and Control Arm bushings
- passenger floor is wet
- 1.7 Valve cover spark plug seals
- 2005 heater problems, no to little heat
- 2002 DX Vibration/Motor Mount Issue.
- Recurring p1259 code (v-tec malfunction)
- 2004 Civic EX: Need help with upstream O2 sensor wiring and testing
- "Help" Electric Grenlins!
- 04 Civic DX auto trans issues... help plz
- D17A2 Valve Cover
- D17A1 swapped to a D17A2
- is the rust on my 03 HX coupe worth fixing?
- Weird noise it's driving me nuts
- EGR sensor output voltage
- 2003 d17A1 Flywheel help!!! .137" cut - .065 cut
- Botched Valve Adj by Honda Dealer
- Headlight issue on '02 civic
- Xmission fluid leak around dip-stick
- Alternator Issue
- Figures - Emission Light On Now
- exhaust manifold swap
- gauge/cluster issues
- I need some help
- transmission not getting gear
- Honda Civic will not start or turnover
- 2003 Diesel--Major electrical issues
- cat clogged or just sensor?
- What would cause light switches to go out?
- 04 Civic Front End Noise
- HF CVT trans 2004
- 2005 civic VP noise on deceleration
- Troubleshoot Check Engine Light; Codes P0420,P0430, P0706 Need advice!
- power window not working
- 2001 ex Head gasket question
- 03 Civic Rear Defrost Not Working
- Car problems after major engine work. Need help/advice please
- 2001 Honda Civic EX hard to start cold.
- HELP: weird vibration at cruising speeds
- Frustrated - still stuck in park
- Idling overheating problem came out of nowhere, afraid it's head gasket...
- 2004 LX Fuel System help please!
- Replacement trunk lid not sitting right
- 04 EX hiccups/jerk?
- What's missing or going on in this pict?
- 05 Honda Civic EX Steering Wheel Shimmy?
- Rattle under d-side of hood around 1500 rpm and also at idle
- Curbed wheel, what bent?
- Car chugging, CEL on, sulfur smell in car...
- Engine Pulley - Warn Woodruff Key - Loose Alt Belt
- 2003 Honda Civic Relay issue??
- Double layer problem
- 2001 lx hopefully nothing too serious.
- Upper Timing belt cover part number, 2001 Civic EX 1.7 litre
- 2004 Honda Civic EX sedan Blower Motor is intermittent
- hood release
- Climate Control
- Air conditioner not blowing cool air
- Headlight cover replacements
- Won't drive in D4 but can reverse.
- New headlight options, OEM?
- Clearance on back Arch problem
- need help with steering/suspension componenets
- Car not the same after trans install
- Mechanical Issues! Please Help!
- Engine Mount
- 2002 Honda Civic LX Gets Stuck in Park
- Help Please !!!!!! RPM hunting
- Can't Get Check Engine Light Off, Tried Everything I Know To Do-- Em2 Civic
- 02 Civic EX Trans Problem
- '03 ringing noise at specific RPM
- 2001 Ex Dumb Question
- Unknown Problem!
- Temp issue
- 04 civic engine noise
- Radiatr for 2001 ex coupe
- heater problems on 2003 civic
- Door Moldings???
- P0122 Throttle body sensor
- Advice Needed Please! - Thinking of buying '04 EX
- Catalytic Converter Failing - Worth Fixing?
- Broken Timing belt
- water leak and its not because of the weather!
- 2003 LX Coupe MT has to be forced into all gears
- Need info on replacing Head gasket and timing belt 89 civic
- Charging iphone 5 on civic '03 si
- 01 LX Gauges, Interior Lights, Warning Beeps
- manual transmission problems?????
- Speedometer needle
- Control arm quality - FCP Import?
- Gas Pedal - really sensitive! ZOOOOOOM!
- Clicking noises when I take off or brake
- Replacing PCM Questions
- 2004 Civic - Help needed to disable seatbelt warning chime
- I need this AC Bracket Help!
- Weird noise suspension?
- Spare key turns starter motor but doesn't fire up ignition?
- 01 Civic LX Steel Oil Pan Gasket little metal rings - wth?
- No neutral?
- My horn doesn't sound right anymore. Did I overuse it?
- check engine.code P1361
- p0336 wont run right
- Sluggish 98 Civic EX D16Y8
- Pulled misfire codes after CEL blinked and turned off
- check engine code p1316
- 2004 Civic DX Won't Start
- Main Bearing In-Car Replacement
- Fuel Injector removal
- flywheel wth?
- Need advice on potential 05 man. trans. problem
- New valves or not new valves? (Head fix dilema)
- ahhh, what is this fell off my civic 03
- 01 Honda Civic - Power Window Issue
- 03 Civic manual trans issue.
- Help testing lock actuator
- 911 !!! Under dash wiring help!!!
- Sporadic Overheating, and more!
- Engine Swap D17A2 out D17A in
- Crank Pulley Bolt Removal method for amateur
- Alternator correlation to p1259?
- Unexplaneable engine noise
- 2001 Civic DX hard to start after replacing fuel pump, etc...
- Throwout bearing or??
- Bearing Codes
- TDC/Cam Sensor installation
- Just installed a new fuel pump. Now hard to start.
- misfire codes
- MIL On with No DTC
- 02 civic no start help
- Rack and pinion replacement/repair
