Fuel Injector removal
Old Sep 5, 2013
jsh1234's Avatar
jsh1234 is an unknown quantity at this point
Anyone have any idea on how to remove the fuel injector from the rail or the intake manifold?
Old Sep 5, 2013
Re: Fuel Injector removal
Typical:
1) Disconnect fuel supply line. Disconnect wiring. Remove the securing hardware from the fuel rail as necessary.
2) I spray carb and throttle cleaner spray all over the rubber seals, this helps them to slide out of the manifold while you lift.
3) All 4 injectors remain attached to the fuel rail, the complete assembly will lift up from the intake manifold with gentle prying. Pry slowly, gently, and evenly.
The rubber seals may or may not come out with the injectors, they might stay in the manifold.
To separate injectors from the fuel rail
If there is a metal retaining clip, remove it.
Twist and pull on the injector.... the only thing left is a fat O ring sealing the injector to the fuel rail.
HTH
Old Nov 2, 2017
DavidKing's Avatar
DavidKing is an unknown quantity at this point
Had to spray the o-rings with some carb cleaner and then it slid right out.
ZeroDegreze
Jun 17, 2015 11:10 PM
green01civic
Apr 29, 2015 01:36 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
htowncivicEX
Jan 21, 2002 11:48 AM
