1.7 Valve cover spark plug seals
I am putting the valve cover back on my 1.7 VTEC. This has been the hardest part of my head gasket change. I replaced the seals that go in the spark plug holes. When I put the cover on should the seals completely cover the top of the spark plug tubes? when looking down in the hole I can see part of the top of the tube. I tried to take a small screw driver and work to seal around the top of the tube but I cant get it. I am afraid to tighten down the valve cover bolts because it looks like it would cut the seal. I called Felpro and they said the spring side on the spark plug seal should face down toward the head. I have a spare cover and that is not how the seals are installed in it. I can't believe this is giving me so much trouble. Tried to see on you tube if I put the seals in backwards but could not tell in the videos I saw. I have to reset my password before I can post a picture to show what is going on. Help please
Re: 1.7 Valve cover spark plug seals
This is looking down in the psrk plug hole. The seal is not uniform
http://tinypic.com/m/ht89as/1
This is how I installed the seal
http://tinypic.com/m/ht89ag/1
I think I got it. I used some small screwdrivers and worked the seal down around the tube. Didn't want to do that but it looks like that is the way they should be. Hope I didn't hurt anything
Your pics look like the seal is installed correctly to me.
Sometimes you have to "help" the seal into the correct place around the tube (small screwdriver).
If the seal would have been left with a lip partially covering the spark plug tube, the tube would likely eventually fill with oil.
See this thread for pics of a tube seal that got caught wrong: https://www.civicforums.com/forums/3...ml#post4634397
HTH
HTH
HTH
HTH
http://tinypic.com/m/ht8ar9/1
If you saw my other pictures of my valve cover I think it turned out pretty good.
http://tinypic.com/m/ht8ar6/1
HTH
HTH
JohnnyBxo
16
May 9, 2015 05:53 PM
Blaster30
Apr 22, 2015 12:21 PM
