- I've been tracking Gas Mileage...
- Oil in air element casing???Need answers
- Grinding gears with clutch in
- My Car Windows Are Fogged As Hell EVERYDAY!
- Anybody else had this happen?
- k20 swap: bad idea?
- Bad Breaks...and everything else
- keeps on fogging up??
- hill parking w/ the crappy auto tranny
- Weird Rubbing/Vibration
- I need another KEY!
- 5th to Nuetral: Look Ma! No hands!
- steering problem
- shaking
- Sealed my headlights again
- Power window question...
- What does the dealer charge...
- when car stop k&b fipk make noises
- PLEASE HELP!
- Notchy shifting standard trans
- Um...strange electric noise?
- Sticky Shifting
- Shifter Squeeking
- help weird vibrations from the passanger side wheel area
- Side airbag light
- '02 EX Firestones = bad handling in rain
- brought car to car wash, now shifter area makes noises
- HELP! My cars battery is dead need info before i tow it
- Transmission Waranty Question
- Still at the dealership
- wierd idle problem
- CAR BATTERY/ALARM PROBLEM
- Custom interior?
- Unsafe feeling at high speeds
- factory ex seat heighth adjustment?
- Creaking?
- Coupe & Sedan different beam pattern?
- Guage cluster
- question on my engine?
- I AM GETT5ING MY AC FIXED FOR FREE
- Went to dealers today
- Is it normal for a
- auto down window stops!?!
- How you rate the 7th Gen Civic?
- wont start!!!!!!!!!
- started car and took awhile to . . .
- rattling under transmission and hand brake...help plz
- I am REALLY starting to HATE 7th GEN CIVICS
- Loud clank when turning steering wheel
- Stock Cd player
- funny odor
- Very dissapointed in my car
- ormal?check engine light blinkins
- Low quality windows on our civics?
- problems with TYC headlights!
- check engine light
- Maint light at ~16,500?
- ?'s regarding blown struts
- diy trunk shocks
- Driver's Seat
- Sedan, Coupe headlights the same?
- Scratches on black bumper! help!
- power steering assist motor making noise?
- Windshield rattle
- warranty??????????????
- Driver's seat seam is seperating
- smells like gas
- Coupe Interior fitment quality issues
- how much is it replace your whole a/c system
- I have a issue with the power window lockout
- Power Windows in Civic
- day running headlights
- MAJOR PROBLEM PLEASE HELP ME ASAP!!!!!!!!!!!
- My new '02 EX woudnt start either...
- Cracked bumper plz help
- problem with projectors
- Stupid Sh@t Wont Start 2K2 Civic SI
- Problems with Cruise Control and Horn
- Sidemarker Question
- Please Read: Serious Help Needed!!!
- Slight Engine Trembles...
- lost reception all of a sudden... twice
- Damn leaks!!
- Engine revs to 6000rpm ON ITS OWN
- Help, Car is chirping
- OK Guys, Steering Problem Linked To Suspention....HELP
- engine swap question
- Oil Drain Interval
- High speed problem
- 02 civic wheel vibration. Bone stock, new
- Headlight bulb only works with brights.
- 20,000 miles, Is it necessary?
- HELP MY CAR WONT GO INTO 1ST GEAR
- Noise from Dash
- Jackin car up
- DIY Cleared Headlights Problem
- Deep Scratch
- weird noise when driving over puddle
- I hate honda part 2....
- weird smell
- Some rattles just can't be eliminated
- i gotta dumb friend
- How much does it cost to drop a manual trans?
- dash kit problem. what should i do?
- Moisture in Headlight - WILD SOLUTION!
- sai makes funnys sound
- Cruise Control doesn't work
- somethings wrong with my civic :-(
- Any one know how to reset the ABS light! Please help
- glove box rattling
- Auto-Pilot ??
- What is the DX engine model number?
- front driver side rumble help
- squeaking noise after hard braking.... what is it?
- hubcaps rubbing against wheel
- Need an explaination of service manager jibberish
- Maint Required light is on??
- Pause when switching gears
- How to take off headlights...
- Question about DC Sports products...
- MAINTENANCE BEFORE WARRANTY EXPIRES
- WTF??? My guages are screwed up
- Driver Side windows rattling when half way down
- DEPROGRAMING Remote entry…how?
- Car Vibrating
- flip tab broke...
- Burned out safety Dome lighting
- squeakin noise from steering & smelly exhaust
- Grindy brake pedal... . ..
- EX Engine noise... any experiences?
- RECALL: ignition switch.
- Check Engine Light & TPS
- I hate honda
- Leaky leak in trunk
- starting the car when the car is already started?
- Fog in cleared headlights. NEED A SOLUTION.
- Car Died
- 02 Civic EX ECU Unstable?
- squeeking noise from rear of car
- NEED HELP ON PANELS!
- SRS and seatbelt light
- '01/02 EX engine rattle
- 2002 EX Auto engine noise... should i
- Vague Steering
- TSB didn't fix it... now what?
- license plate rattle
- HX CVT rumbling at low RPMs
- 2001 Honda Civic Problem
- EX Cluster in DX??
- windshield glass too soft?
- Downshifting Resistance....
- Squeeky clutch pedel
- Drivers' Side Seat
- RESET MAINT REQ'D INDICATOR AFTER 20K MILES
- the SMALL things that annoy you about your car
- AHHH!!!!!!!!!!!!! NOOOOOOOO!!
- Tie Rod Boot (Suspension)
- Engine Maintainance @ 8000???
- TRUNK LEAKING WATER!!!
- Ive ran into some Difficulties....
- How to turn off SRS after installing aftermarket wheel??
- honda recall???
- Engine Check Light/PCM?/ Honda Jackasses
- wooble wooble
- new intake-worse gas mileage, how?
- Check Engine Light/Gas Cap
- I need info on how the kaminari body kit and z3 fenders fit on our cars
- Handling.. and getting service for your broken 7th Gen
- Holy S*** Batman! NHTSA is posting complete TSBs on their website!
- Needles Sticking with new guage faces....
- Ford Focus, being Recalled for Front suspension malfunction and Z-tech engine catching fire.....SO
- i broke my shifter what do i do
- Am I slower than the rest?!
- Problems, Problems and MORE PROBLEMS!!!!
- 7th gen problem solved
- Headlights won't light properly HELP PLEASE!!!!!!
- Cheap plastic interior
- ran over flat tire on freeway...
- bulbs
- Car pulls to the left under acceleration...***UPDATED***
- New Wheels
- !!! General Maintenence Tips !!!
- Headlight has water in it
- ticking noise
- Injen CAI --A/C Keeps coming on when I try to turn on defroster???
- Loud rattle at idle!
- Why does it keep revving?
- where is 02 sensor locateD?
- OIL COMMING OUT OF INTAKE FILTER ?????????
- REPORT PROBLEMS TO NHTSA
- Any on with a turbo have problems with there map sensors?
- Clunking Noise
- Double Clutching...
- problems with autos?
- Where To Do Oil Change
- How Often Do You Have To Take Your Car To Maintenance?
- 7th gen civic slow?
- headlights
- Weird, but different whining noise!!
- i can't see my deck properly!!!
- Long trip results in whining engine
- Popping out of 1st
- Rear Defroster = No Radio Reception
- Rear Defroster NOT working
- OMG MY AIRBAG IS GONNA POP OUT
- Clutch pedal prob
- whistle from dash
- Weird Almost Vibration sounds comming from Inside Behind Drivers Side
- Auto Lock???
- BRAKE PROBLEM, HELP!!!
- HORRIBLE BRAKING SOUND
- got Dent?
- I need HELP BAD!!!!!!!
- ... and also, anyone have a squeaky clutch pedal?
- anyone have air come out the side vents on defrost only mode??
- power steering fluid
- side airbag light
- turn signals/heaters
- What the heck happened to my brakes?!
- two rubber thingys that came with my SiG but weren't installed...
- Less rattles when damp?
- 2ND GEAR ISSUES
- MY HOOD WONT CLOSE ALL THE WAY!!
- paint flaking off bumper, repaint under warranty, WOOHOO!!
- Door Fabric
- Shifting between 2nd and 3rd makes noise
- knock
- Lowered Civics....Damage to under engine?
- Tranny Jerking
- Grill help
- To all those with the moonroof/headliner rattle...
- 2 things that bug me
- car pulls to the right
- gas tank door sticks ??
- Power Windows Squeaking
- Malfunction Indicator light went on
- Howling noise 60mph+
- great ways to spend $969???
- clutch problem
- maintenance required light HELP
- Downshift Kicks
- Automatice Redlining
- Car won't start, Battery keeps dying over night???
- I see corrosion on my tie rod...
- what coulda caused this? plz help!!
- Right Turn Signals Shorting
- Lowered, now it clunks
- Suggestion/help on paint scratches
- Anyone get a lilttle 'whistle' when clutch is disengaged?
