PDA
View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50
  1. ATTN SOMEONE GIVE ME THERE IDEAS????
  2. Octane Ground Effects
  3. dealership woes (venting: very long story) *update*
  4. HID problem/ stock fog light
  5. Melted fuse box
  6. Rear seat lock
  7. Wire in engine bay.
  8. how lound is your engine at redline??
  9. Finally found the most annoying rattle
  10. LX Launch Technique / Shift Points anyone?
  11. Rear deck rattle
  12. Cars turns off for no reason....
  13. Weird noise after disengaging clutch
  14. NOISE!!
  15. What would a leaking strut affect? Just curious
  16. My Car Shakes...Do these Hub RINGS look right
  17. Neon ?
  18. question on maintenance icon in dash
  19. to all moderators, and any with major engine experience
  20. Coilover noise
  21. i can't get my pics smaller than 100kb??help!!
  22. How to drive the 2k2 civic lx with AT?
  23. RPMs drop WAY low
  24. Spare Tire Came Loose!
  25. Hp headers with High flow cat
  26. A/C vents
  27. heh, I just did a search for 2k2 service bulletins...
  28. turning question
  29. 10k mile check, HOW MUCH $$$$$$??????
  30. Ticking noise fixed
  31. The non-US Civics...
  32. Paint peeling/chipping on '02 LX?
  33. Need help!!!!
  34. Any Advice on Steering Shake with new wheels??
  35. Drivers' Side Windshield Wiper Hits A-Piller
  36. trunk messed up
  37. CONT. ITS OVER ........I can,t take it anymore.
  38. Engine Shuts off
  39. THROTTLE RESPONSE GONE TO SHI7
  40. any one having a problem setting the clock?
  41. any problems with...??
  42. Are the LX,s less trouble prone than the other models....just curious
  43. Headlights & Interior Lights Dimmed (Part II) - Civic GLI Australian Model
  44. Dents
  45. errrr. .. side airbags
  46. Cargo net
  47. rear seatbelt grinding sound
  48. 22000 miles and the brakes vibrate
  49. brake light doesn't work
  50. Foggy windows??
  51. Suspension leaning?
  52. how do you know when a strut is blown?
  53. Spark Plugs
  54. rear suspension in big trouble
  55. Braking-A/C PROBLEMS
  56. paint chips
  57. KEY STUCK IN IGNITION
  58. squeeking rear shocks
  59. weird smell form air conditioning
  60. question on maintenance light on dash???
  61. Taking my car in for service... Do I Get a Loaner car?
  62. HELP!
  63. Buzz/Squeek/Rattle: Driver Door
  64. Car Hesitates on takeoff...
  65. steering wheel turns funny
  66. another waranty problem....
  67. the grinding/scratching noise again!
  68. power steering system or the rack...........
  69. Injen intake sucked up water Engine is dead
  70. mileage question
  71. BIG PROBLEM AT DEALERSHIP
  72. sputtering when enguaging clutch in 1st gear
  73. cable broke for truck and gas tank
  74. Hot day, now my gauge needles are stuck :(
  75. the new honda's
  76. have i voided my warranty?
  77. Engine whining noise
  78. Found mouse nest in my trunk
  79. please help...
  80. Has anyone had any hesitation when starting the engine?
  81. i have a problem
  82. Coolant Level
  83. I HAVE NO LOWBEAMS HELP!!!!
  84. tranny mount.....damaged gonna be replaced under warrantee
  85. 2k1 stalling problems, thinking of selling car
  86. 2ND GEAR KEEPS POPPING OUT...HELP!!!!
  87. leaking?
  88. kinda sluggish
  89. roaches in my intake
  90. vibrations due to low rpm
  91. car stalled and wont start...
  92. Air Conditioning - Not too cold...
  93. Recall For Idle Problem
  94. Firestone = Poo
  95. driver's side floor Damp/Wet.
  96. Roaches in the vents...
  97. Engine - Uneven power when cold ( lurching)
  98. problem inside the gas tank
  99. reflective tint in FL
  100. Air conditioner filter source?
  101. Some dash damage, help?!?
  102. squeeeeeking hmmm 2k2 civic sedan WADDUP WIT DAT.
  103. weird problem in the rain
  104. Paintless dent repair/removal : review
  105. Please search.
  106. hole in seat
  107. Grinding Gears
  108. bad seats?
  109. DEAD CYLINDER!!!!!!!!!!!!!!!!!!
  110. Coupe Seats Head Tilting
  111. shaking at 75mph+
  112. lemon law ma?
  113. clicking noise
  114. Power Window Problems
  115. PAINT ON TRUNK FADING!
  116. Windshield Cracked
  117. Symptoms of a lugging engine?
  118. Free Dealer Car Wash F*D my Car.
  119. Not always starting up?
  120. Rattle when I accelerate
  121. how do u know when brakes should be changed
  122. how often do u change the oil and do u need to buy a new oil filter
  123. Fenderwell trim
  124. GASoline smell???
  125. Windshield Cracking
  126. Engine problems
  127. 2002 Civic Coupe LX is hard to start
  128. EXHAUST RATTLE?????
  129. got a squeel under your engine???
  130. brake noise
  131. I AM LOCKED OUT !!!!
  132. My Car Going Crazy!!!
  133. headers turning red
  134. warranty work- fix one thing, screw up four things
  135. Another Honda with excessive clutch travel!!
  136. Satin Silver Metallic Bumper Paint - Hard to match??
  137. idle problem
  138. alarm.....wierd
  139. Headlights dimmed briefly when you take your foot off the pedal...
  140. whats up with the ticking engine??
  141. 2002 Honda LX - Lemon because of noise
  142. Leak Underneath When Using the A/C
  143. ECU Wiring Harness Layout Question
  144. transmission?
  145. muffler install headache
  146. WRITE HONDA TODAY FOR RESULTS...
  147. Engine running too rough. Please Help!!!
  148. KEY STUCK IN GAP BETWEEN WHEEL AND COLUMN!
  149. Antenna sucks
  150. Your biggest problem with your 7th gen...
  151. Suspension FIXED
  152. HID & Projectors...
  153. Bouncing in the back of car
  154. Breaking in a new 2k2
  155. What do u call this problem?
  156. If you got new tires/rims, alignment is NOT required
  157. Gearbox grinding!!!
  158. My steering wheel is shaking! Help!
  159. this engine grinding has got me worried.........wtf...........
  160. engine noise
  161. Damp Seatbelt and Wet Window
  162. AC not getting cold enough
  163. accidents SUCK!!!
  164. Can your driveaxles be bent?
  165. New Rims and Tires = Alignment
  166. AIR CONDITIONING
  167. Noise in front end (new springs)..Need help!
  168. squeeky clutch pedal
  169. HONDA QUALITY......PROBABLY AS GOOD AS IT GETS
  170. Slow braking 7th Gen Civics?
  171. Hot headlight
  172. shaving red car???
  173. Is the problem with Honda Coporate or Honda the dealer??
  174. sand in car seals
  175. My little horror story
  176. Front Struts
  177. Warranty/Exhaust Info
  178. horrible mileage
  179. HONDA FRONT AIR DAM
  180. crashed front............
  181. Squeaky noise from engine!!! What's up with that?
  182. Peeling Paint
  183. Tailights!
  184. Hyper Blinkers
  185. axle boot leaking
  186. Inaccurate Fuel Gauge
  187. fog in my headlights help!!!!!
  188. I am such an idiot...
  189. shifter rattle in 5th gear
  190. window moves the door???
  191. Meddling Kids!!!
  192. breaks squeek
  193. FYI A/C Woes
  194. tire rotate?
  195. Shocks Worn Out?
  196. weird buzzin noise from speakers
  197. Transmission problems
  198. Headlight is messed up
  199. bad ride quality?
  200. Tinted windows weakened radio signal
  201. Overcoming the Strut problems!
  202. Can you drive without 2nd gear!?
  203. Do alloy wheel improve ride comfort?
  204. weird grinding noise
  205. car pulls to the left
  206. Emblem reattachment
  207. list of all service bulletins?
  208. 02 LX ITS OVER!!!!!!ICANT TAKE IT ANYMORE PART2
  209. Why did u guys void ur warinties on ur Civics
  210. OMG what a pr*ck!!!!! Hoehn Honda, San Diego sucks!!!!!!!
  211. brake ..... click ....
  212. Brakes Grabbing
  213. vibrations
  214. Cigaret Lighter Broken What to do?
  215. used 2k1 prices?
  216. Power steering is hard.
  217. windshield washer nozzle spray stains
  218. Oil Question
  219. Door cover
  220. Running Low on Gas?
  221. Loud "clunk" noise
  222. Reloacted Alarm Speaker, Car won't start?!?!?!?!
  223. Scratched rims
  224. why cant i turn the a/c off while defoging?...
  225. SRS airbag light on all the time
  226. New Rattle
  227. OMG...What have i done...
  228. Vibration at idle
  229. Smells like burnt plastic/rubber
  230. I can't believe this.........went to service again.
  231. Warning : Your battery is about to die!
  232. Rear end crazyness, Speed Bumps
  233. knocking suspension only when moving slow.
  234. 02 LX ITS OVER!!!!!!!!!!!!I cant take it anymore
  235. CUSH HONDA IN SAN DIEGO SUCKS
  236. Upgrade Wheels/ Faster Odometer
  237. Screetching Brakes
  238. Radio/Defroster Problem!!!!
  239. Keeping a clean engine
  240. Strange noise I can't get it fix.........need Help.
  241. PLEASE HELP!!! SRI Installation; Malfunction Light on?!
  242. BYPASS SECURITY FOR COMPUSTAR???
  243. Silicone caulk on my bumper
  244. My Engine is DONE!
  245. fogging in headlights?!!! =(
  246. clearing headlights for POS 4 door civic to hard
  247. POS Governor
  248. Fuel Tank Level - Inconsistency
  249. SOMEONE WITH A SHOP MANUAL
  250. Auto tranny question
