Emblem reattachment
Old May 2, 2002
Assasin's Avatar
Assasin is an unknown quantity at this point
Emblem reattachment
ok i shaved my LX logo off today everything went fine and i got a extra civic emblem and took the V I I and i bout ssome double sided tape to put it back on its like foamy ish and it attached but there is a big gap between tyhe emblem and logo what stuff shall i buy to attach my VII emblem on? cause this double sided tape people can jack my ish quick. where to buy it wud be nice tooo plus it looks pretty bad *** ill get pictures this weekend
Old May 2, 2002
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
I'd say to either get the really nice and thin 3M double sided tape, or to try a glue of some sort. I actually ran into a similar situation with my dash kit today, my vent pieces wouldn't stick using the included double sided tape, so I went and bought some "medium strength" Elmer's multi-purpose glue. Worked wonders, and I can still remove later on if I really need to. Just use a very small amount, hold it in place (or use masking tape to hold), and then maybe hit it with a hair dryer to speed things up. Good luck
Old May 3, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Get some 3M Emblem Glue. Comes in black tube. Its a bit of a pain though. You'll get stringy glue hanging off the sides if you're not careful. You gotta work fast too. The top layer dries in about a minute so you'll have to use more to get it to stick well.
-Kre
Old May 3, 2002
Assasin's Avatar
where can i buy this stuff
Old May 3, 2002
JSWhaler's Avatar
JSWhaler is an unknown quantity at this point
ya once you apply the emblems use a heat gun or something to warm up the emblems and apply pressure so that they stick a little bit better.
Old May 5, 2002
insan's Avatar
insan is an unknown quantity at this point
if u don't ever want to take it off use SUPER GLUE..
Old May 5, 2002
RichardCranium's Avatar
RichardCranium is an unknown quantity at this point
You can buy emblem glue any where that sells auto painting suplies. Also the more you use the longer it take to dry and less glue is stronger.
Old May 5, 2002
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
you can buy the 3m heavy duty double-sided sticky tape @ most craft sotres, wal-mart, automotive stores, just about anywhere. if you get the heavy duty, it will come in a roll of 10 to 12 feet, and have a red backing on it. gonna run you anywhere from $1.50 to $5.00, depending on where you buy it. but, it is the same stuff they use at most dealerships, that's when they put most of the emblems on.
UltraHDGames
Jun 8, 2016 05:16 PM
7thgensurvivor
33
Sep 5, 2015 08:20 PM
naokigoffi
Aug 30, 2015 06:19 PM
sf3r8z
Aug 11, 2015 02:32 PM
JoeNC
Dec 22, 2001 03:18 PM
