My Car Shakes...Do these Hub RINGS look right
Old Jul 6, 2002
Ben's Avatar
Ben
Ben is an unknown quantity at this point
Do these Hubs look right???
ok i posted before about how my wheels shake aroun 60 or so. well i was just wondering if you guys can tell by these pics if i have the right hub centric rings. they look close to me but i'm not sure how tight they really need to be. my next step will be getting them balanced again and have them use the weights they tape on in the middle i guess.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] hubs 001.jpg (62 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] hubs 002.jpg (61 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] hubs 003.jpg (62 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] hubs 004.jpg (61 Kb)
Old Jul 7, 2002
Macko's Avatar
Macko is an unknown quantity at this point
Is it supposed to be dented like that?
Old Jul 7, 2002
Lococoin's Avatar
Lococoin is an unknown quantity at this point
Quote
[hr]Originally posted by: Macko
Is it supposed to be dented like that?[hr]
if your talking about the dent in the axle nut, its suppose to be there, its a crude way of locking the nut so that it cannot come off
Old Jul 8, 2002
AirForce's Avatar
AirForce is an unknown quantity at this point
What brand are your rims, because if they are cheap then that might be the case, or it could be your tires, or your centric rings are crap, Just check into all of that and see what you come up with
Old Jul 11, 2002
dezod's Avatar
7thgen Power Maker
i had that problem, but it was attributed to the tires not being properly balanced.try that.
Old Jul 12, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
The hub rings look right, most likely it is the balancing...had the same problem and had them balance the wheel, putting the wheel weights in the inside of the wheel and to this day, no more vibration...
2Hottie
Old Jul 14, 2002
Pete's Avatar
Pete is an unknown quantity at this point
I agree that a wheel and tire balance is needed. Find a shop that can do a high speed balance.
As an aside, are the wheel nuts tightened in your pictures? If they are, I would get longer studs inserted. Or change the nuts to ones that fit. Looks like the rim is fairly thich and the nuts are just on by a few threads.
Pete
ChristinaVHH
May 10, 2015 03:51 PM
LionSpratt
Apr 26, 2015 01:02 PM
TheRubixHorse
Apr 17, 2015 08:55 AM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
artychris
Oct 24, 2001 10:14 AM
