PDA
View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. rear noises
  2. anti-seize
  3. driver door jammed and wont open
  4. Acura EL Automatic Transmission Problems?
  5. Weird Motor Fuction..... Might be an Idle Control Valve
  6. mt shudder when cold
  7. Clutch makes popping noise
  8. Yep, so it happened today. The vics auto tranny is now completley shot. Towed away :(
  9. Honda is Covering my 2002 AT 100%
  10. Noise Diagnosis ..
  11. gauges all @#%&!* up...
  12. Abs Sensor, Broken Mirror Gas Remote Broken Need Help
  13. TSB's and Warrenties
  14. P1298
  15. Check Engine Light clears upon restart, no codes?
  16. Nothing coming out of lower air vents
  17. code 1259 vtec malfunction
  18. wierd noise at low rpms
  19. 2001 Civic EX auto electrical problems
  20. Clear Coat Peeling
  21. For ppl with turbo and 3 inch catless exhaust
  22. gas door...can we lock it?
  23. how do you turn off maintenence required light???
  24. Front Driver Side Creaking
  25. Checking with others: Funny problems in my cars
  26. Shifting Problems..... HELP!
  27. Wheel Sounds
  28. Trouble diagnosing P0563, P0141
  29. 3 rear left speakers broken in 4 years
  30. Failed AT Transmission
  31. Aftermarket Tachometer on DX 05
  32. A/C Sucks
  33. OBD P0135 for O2LX 2000
  34. Engien Light on ?
  35. OBX headers 2nd O2 sensor question
  36. rattling noise at idle and under load
  37. werid sounds commin from the vic
  38. I tried to search but nothing... Steering wheel alignment
  39. Jack Accident (Laff at me)
  40. CAI after install
  41. HONDA FOR LIFE but NEED HELP PLEASE
  42. Spontanious Decelleration
  43. Brake problem and random noise!!! HELP!
  44. Paint chip on roof
  45. Window Problem...
  46. Smoke from exhuast
  47. I keep blowing alternator sp fuses
  48. 2002 Civic Automatic Transmission Problems HELP!
  49. HP Racing header
  50. I need Schematics please help
  51. wheel bearings
  52. Torque Converter Clutch Malfunction
  53. Anyone have loose door latches?
  54. Almost stalls with AC on
  55. Timing Belt due?
  56. "compliance bushing" ?
  57. Brake lamps don't work (rear brake lights and the small one against hte rear window)
  58. Transmission ?'s
  59. Two Separate issues, Clutch and CV Axles?
  60. My dilema need help
  61. squeaky brake pedal?
  62. It got caught...
  63. 5 check engine light flash.
  64. Accord engine noise/grind throttle only
  65. a/c compressor
  66. 2001 Tranny re-call?
  67. Warranty Issues
  68. Name That Part!?!?!
  69. Helpppp
  70. brake squeking like a mofo
  71. Does anyone kno how to rip off the ignition on our 7th gens!!!
  72. HELP nothing lights up
  73. Noise and bad shaking from front rightside
  74. Hit a curb the other day Question
  75. a/c noise??
  76. clutch pedal squeak!
  77. Cutting off Catalytic Converter??
  78. Humming noise coming from front?
  79. ac condensor is bad,anyone have a spare, will warrenty cover this?
  80. ac condensor is bad,anyone have a spare, will warrenty cover this?
  81. $$$$$$ How Much Will This Cost?????
  82. progress rear swaybar
  83. idle drop
  84. Will 4dr headlights fit on a 2dr?
  85. Engine Sounds Like A Diesel Engine???
  86. i think i got a serious problem... wheel,axle, rotor assembly is loose? HELP ASAP!!
  87. Exhaust noisy at cat/header
  88. 2002 civic making noise
  89. P0420
  90. Smoky fron the front
  91. ignition help
  92. Could someone post the name of that act of congress protecting warranties?
  93. a little confusion with cats, downpipe...
  94. Break bios
  95. tranny
  96. odometer
  97. Who has done a d17A1 to d17A2 swap
  98. Who has done a d17A1 to d17A2 swap
  99. Weird problem
  100. headlights take time to come on
  101. Noises in the rain
  102. Help with Valve/Cam
  103. my suspension is popping
  104. What to do to car at 60,000 Miles (Need Consensus)
  105. ?¿?NeEd A PrIcE?¿?
  106. change of TDC Sensor
  107. Squeeking Rear all of a sudden?
  108. 04 vp wont start help!!!
  109. ShAkInG FeLt On RiGhT SiDe
  110. A/C compressor oil
  111. Win a Honda Civic
  112. My vents won't blow any air...
  113. Civic won't start!!! PLEASE HELP!!!
  114. DIY Diagnostics???
  115. Engine Problem
  116. edmunds trade in prices
  117. Fan question
  118. Problem with trunk springs.
  119. It rained HARD and now this happened...
  120. Gas Tank Cover will Not Open
  121. electrical problem
  122. help!!! need help with ebay fogs.
  123. should you mix your gases
  124. hood lock problem
  125. Weird fuel gauge and tank issue
  126. clutch hydraulics
  127. Window problem
  128. 05 engine harness rewiring
  129. Things are bad fro the vic right now
  130. P0139 Error Code 05 Civic after header
  131. How much to rebuild a D17?
  132. New Exhaust Installed but there's a burning SMELL
  133. Engine Grind? wtf?
  134. P0122 TPS '03 Civic LX
  135. Stiff auto shifter...
  136. Rattling Noise???
  137. Looking for recall info
  138. 02 Civic Won't Start
  139. 02 Civic Won't Start
  140. driver door lock wont lock
  141. Question for 04-05 Civics with autos
  142. trouble with losing
  143. Odd sound when turning
  144. Ex and Si crankshaft help!!!
  145. take my car to the dealer or mechanic??
  146. road noise
  147. just cracked the 100,000 barrier
  148. Where can you buy this in Toronto??
  149. valve adjustment problems
  150. gotta a promblem please help!!!!!
  151. Warranty Question
  152. 2001 EX with Auto... How many quarts are you adding?
  153. Squealing whistle off throttle
  154. new guy with simple question
  155. Installing Parts and Diagrams of parts
  156. radiator hose wont fit.
  157. A/C Smell
  158. '05 Civic EX, 25000+ Miles, Doesn't start as easy
  159. Need help with HOOD problem
  160. Low beams quit working
  161. someone hasta KNOW ..PLEASE
  162. Slipping out of 3rd gear while decelerating?
  163. Fallson Its Face
  164. SRS light / Seat Removal
  165. Heat Guage going to HOT when idle or in bumper to bumper traffic
  166. Dis-able the annoying loud *ss buzzer!
  167. aiming headlight
  168. B&M cooler for auto trans
  169. cv boots.....
  170. Knock Sensor
  171. vibration under the car from the cat
  172. funky smell inside
  173. 03 Civic:MT tranny whistling? | Page2: upgrade clutch during bearing replacement?
  174. noise coming from rear struts??springs??HELP!!
  175. 2005 civic cabin filter?
  176. Sounds Like Detonation??????
  177. Destroyed E-brake
  178. Leak in 01 LX 4D.WET Driver Side Carpet
  179. OIL All over spark plug... ?
  180. Bad Day with Coolant Leaking
  181. REQ: Recall Info
  182. Cluster lights flicker on and off
  183. Rebuild or Swap... 3 questions.. Help me
  184. Had a random overheat, kinda mind boggling
  185. ok, header and high flow cat
  186. Removal of silver trim piece around shifter?
  187. rim & shaking steering wheel
  188. problems starting sometimes
  189. Need Help Radio won't turn off
  190. 02 Civic HX noise
  191. Suspension and Catback problems! Sh*t
  192. taillight fuse??
  193. Misfire out of ideas!!!!
  194. radio dead , power door locks quirky
  195. screeching sound help
  196. TCI Automatic Ovehaul Kit
  197. Need some Advice on wat had happen to my civic
  198. idling to low?
  199. What shops do leakdown tests?
  200. OBD2 code: P0420 Catalyst System Efficiency Below Threshold
  201. Hhheeellppp!!!
  202. Engine heat issue?
  203. Side airbag light
  204. alternator??
  205. Cruise controll question
  206. Is this normal?
  207. Key is hard to turn
  208. Clunking noise when turning the wheel?
  209. Hope someone can help me out, major electrical problemo
  210. Sedan Rear Side Window Rattle
  211. i cant see my damn antifreeze level!!!!
  212. check engine code p1457
  213. Exhaust Manifold Crack = Lean?
  214. 2002 EX coupe: Tumbling/clicking while turning right
  215. Replacing bulbs in the Gauge Cluster?
  216. Front windows stopped rolling at the same time.
  217. giving up hope on my POS, tranny problems.
  218. What Are The Signs Of An Auto Tranny Going???
  219. Car wont start, key won't turn?! help asap.
  220. my car is sick. lol *update#5*
  221. Maintainence REQ'D
  222. Greddy Evo2 Exhaust Problems
  223. 3rd gear pops out time 2 time
  224. Electrical issue...ugh
  225. Wierd gauge cluster quirk
  226. My day at the Track.
  227. weird noise when takeing a turn
  228. Headlight problem...
  229. tsi piping rubbing
  230. squeaking/high pitch grindin sound ....
  231. tsi control unit problem
  232. Get a new tranny or sell the car?
  233. auto gear shft indicator lights!!
  234. compressor problem!!!
  235. check engine light fuel temp?
  236. Valve Cover came off...
  237. Unable to shift to park gear smoothly on AT.
  238. squeaky nosie when car is running
  239. Just look at the picture and go "WTF" with me lol
  240. mys srs light is on!
  241. Radio Time Set
  242. Oily Air Filter
  243. Keyless Entry or Not?
  244. 03 manual trans. problem
  245. oem fog switch, wired to neons
  246. Power Windows
  247. Any way to test the condenser fan?
  248. sh1t, stripped a bolt....
  249. fuel gauge question
  250. need help on installing volt meter
