Engine Grind? wtf?
Old May 24, 2006
chaoticmav's Avatar
chaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trustedchaoticmav should not be trusted
Engine Grind? wtf?
When ever I accelarate its horribly slower then usual, AND when I let the engine reduce its revs (lift foot up off gas) I hear a grinding noise, wtf?
I checked my oil and it seems ok, I can not pinpoint the sound other then the front of the engine, my engine light is on for an "emissions" error, but nothing else, it does this in all gears (I have a automatic) P/R/N/D/2
Old May 27, 2006
Geek94's Avatar
Geek94 is an unknown quantity at this point
This thread is old but I'm getting that noise now too. I can usually hear it from 3rd gear and all the way down to the 1st gear. I found this topic that could be the answer as i have an odd noise wen it's in neutral but I can't post the link because I of the forum anti spam thing. Message me and I can give you the link
Old May 28, 2006
chaoticmav's Avatar
No need now, thanks for information regardless though.
I took it to honda, Cat was plugged, but I also need an overhaul on the engine.
I loser.
Old May 28, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Hold onto your lug nuts its time for an overhaul!
Seriously, how many miles you have on your car?
Old May 29, 2006
chaoticmav's Avatar
63,xxx
Old May 30, 2006
s13_240sx_92's Avatar
s13_240sx_92 is an unknown quantity at this point
did you run leaded gas? the cat shouldn't just plug up like that. did you overheat the engine? burn your valves?
Sounds like the dealer is getting ready to bend you over..
Old May 30, 2006
chaoticmav's Avatar
The cat is going to be covered for no charge.
I don't think the dealer is doing me TO bad, I know the seals/gaskets are all bad.
Blazz
Jun 4, 2015 01:04 AM
edgenet
May 2, 2015 08:00 PM
EC3
Apr 22, 2015 07:55 PM
Vinas
Transmission
Jan 3, 2002 06:56 PM
klectic
Canada West
Dec 15, 2001 02:57 AM
