2001 EX with Auto... How many quarts are you adding?
I hate the trans dipstick on this car
When I drain it I think it takes 3 quarts to get to the full line on the dipstick. At least that is the best I can tell with the way the fluid sticks on it. How many does everyone else use when doing a change-out.
BTW... I put the Honda ATF in this time instead of Dexron so I am curious to see how it differs in shifts. $34.00 for 6 quarts = Honda is making a fortune off this stuff!
Talked to the Service Dept. again they say they don't get Civics in with trans problems.... only Accords
Oh.... 38,000 miles so I have more than a few that had smoked ones by this mileage
When I drain it I think it takes 3 quarts to get to the full line on the dipstick. At least that is the best I can tell with the way the fluid sticks on it. How many does everyone else use when doing a change-out. BTW... I put the Honda ATF in this time instead of Dexron so I am curious to see how it differs in shifts. $34.00 for 6 quarts = Honda is making a fortune off this stuff!
Last edited by Intercooler; May 19, 2006 at 09:38 PM. Reason: Automerged Doublepost
I though it was 3 quarts for drain and fill.
What I hate is how all the crud builds up on the flat surface around the tranny dipstick opening, I try to keep that cleaned off for fear a chunk of it will get into the tranny when checking the level.
when are we suppose to drain the fluid? My 01 has 44,xxx miles and I never changed that or anything else just my oil.
i do it every 10k. it maybe changes 1/3 of the fluid cause most is trapped in torque converter and cooler. i've heard many things. Some say that changing some of the fluid causes buildup to be reseased and clog the trans filter, others say if you dont change then same will happen so who knows. flushing isn't supposed to be good either.
jdh022764
18
Nov 3, 2015 06:44 AM
meicalnissyen
Sep 25, 2015 12:12 AM
BBrosario
Sep 17, 2015 07:51 PM
JMKendrick
Sep 16, 2015 06:17 PM
tavisc
Sep 15, 2015 07:46 PM
