PDA
View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Every window but driver doesnt work :(
  2. Replacement spare tire??
  3. rear dome light
  4. 01 civic problems?
  5. recalls!!!
  6. 2004 Civic EX sedan weird noises starting from a complete stop
  7. anyone with trans probs?????????????
  8. passenger mirror easier to clean?
  9. Power Stearing Fluid
  10. black oil in h22
  11. how do you deal with...
  12. 03 center console question
  13. tyc headlights
  14. Never Ending Vibration Problem? Any Ideas Here
  15. Blower Motor
  16. blown transmission!
  17. clutch cylinder problems
  18. Dang the Engine Light
  19. Well this chaps my ass
  20. Well this chaps my ass
  21. reverse actin weird
  22. 2001 ex sedan problems
  23. light recall
  24. Projectors
  25. OMG almost phuked up LARGE !
  26. Squeaky noise from suspension
  27. car wont start!
  28. Fuel Gauge Incorrect
  29. can you tell me whats wrong with my car?
  30. alternator
  31. sway bar problem
  32. RPM 4100 and check engine light
  33. How does you car sound??
  34. bad struts in 01s? recalled?
  35. Should I be worried....
  36. electrical stuff won't shut off
  37. My 04 Civic EX Coupe needs your help.
  38. "THE GREAT BLIZZARD OF 05" SUCKS!!!
  39. inside door handle is pealing
  40. Help...
  41. Windshield Scratching
  42. 04-05 fogs, anyone have a lense crack yet?
  43. Shaky rear view mirror
  44. Please help me out guys!!!
  45. CEL P0505 Help
  46. Any chance Honda will hook me up? If not, help me please on DIY.
  47. I got a leak somewhere!!!
  48. cam gear
  49. fuel injectors? 1988 corolla carb
  50. Hey you Auto Tranny guys...
  51. help..car would not start
  52. whirring sound on startup
  53. 2002+ Si Shifter
  54. o2 sensor question
  55. wheel stud removal??????????
  56. Turn signal blinker not working
  57. Idles at 400 and kinda sputters like its gonna die
  58. Bringing the car to the dealer again...what do youthink is wrong? **UPDATE**
  59. Manual Trans Fluid
  60. warrany troubles please read
  61. my custom gauges dont work
  62. is it a dead battery or alternator?
  63. Help with gauge cluster!!!! Speedometer is reading wrong
  64. Anyone know how to get around the OEM Radio code???
  65. Why the heck does it double post weird
  66. No more beeping sound
  67. If You have A Automatic Transmission, Do Me another Favor?
  68. oem cd player reads cd error
  69. plug under right headlight goes to nothing???
  70. problem wit lights
  71. Possibly fried some wires
  72. Automatic shifting into ?3rd? revs..
  73. To Those Who Have a Automatic Transmission, Please Do Me A Favor???
  74. OEM Header Problem
  75. Still having cooling fan issues...
  76. Knocking Sound when shifting
  77. Alternator went bye-bye
  78. SRS Lights
  79. transmission solenoids
  80. Abs
  81. Who Has......
  82. Maintence required...
  83. Problem with Charging System?
  84. Cracked fog lights covered under warranty!!!!
  85. adjustable fuel regulator
  86. whining noise?
  87. Should I take out my AEM SRI before going to my 40k maintenence checkup at the dealer
  88. Need Help!!
  89. Maintenence Light FAQs *Please read before posting*
  90. Brake Fluid Low
  91. Maintenence required
  92. Maintenence required etc.
  93. Clutch Pedal Squeeks
  94. 04 coupe pulling to the right.....
  95. seatbelt tension on 01'' coupe
  96. SRS Light on!
  97. Momo Steering Wheel Installation
  98. 01 -03 exhuast install Q
  99. AHH Audio Code
  100. Malfunction Light
  101. Bent Valve
  102. P0141 OBD2 code
  103. here we go again. b!tch wont stay in gear
  104. Overhead Lights?
  105. car giving off smell
  106. Tranny/Clutch Problem
  107. Tach prob
  108. Subwoofer setup wires?
  109. Well I encountered my first Problem with 2005
  110. how to retrieve a screw that fell into front vent holes
  111. rattling sound from dashboard
  112. tranny
  113. HELP: oil pressure light comes on, car stops accelerating; restart and it's fine
  114. uh oh?
  115. Exhaust question
  116. Problems.....
  117. MP3 and Text...???
  118. you think this is covered under warranty ?
  119. Big Noise when it rain in my trans
  120. Ending to Tranny Problem
  121. Wierd metal grinding noises?
  122. Knock Knock....What's there???
  123. How cam I reset my cluster?
  124. engine idles w/ a different sound
  125. blown headgasket...warranty DENIED...please read.
  126. '04 SiR Fuel Capacity Myth
  127. Help!!
  128. automatic window troubles
  129. Bubbled Paint
  130. ABS and SRS light come and go
  131. Trunk Bounce?!
  132. Check engine light from snow "drifting"
  133. Help me out with my vic not startin
  134. Manual Tranny...
  135. HELP!!! Engine Popping
  136. Manual trans service
  137. Air Leaks
  138. Wrecked my car
  139. Scratched Headlights
  140. bad indaglo gauges
  141. Tip for clearing condensation on windows
  142. Low idle weirdness?
  143. Crack in Windshield / Warranty?
  144. Healiner Removal?
  145. Heated power mirrors
  146. 30k Maintainance
  147. Exhaust rattle against sway......
  148. Rubber Guard under Front Bumper
  149. second gear slipping
  150. stupid noise around 2500 rpm
  151. So pissed!!
  152. CEL map/baro low voltage detected?
  153. O2 simulator fix P0141 obd2 code?
  154. my car stalled
  155. Truck Won't Start
  156. My stock spoiler n trunk are getting spots
  157. power windows
  158. i think somethings wrong...
  159. some wierd noise and feeling
  160. My car not the same car it was 34,000 miles ago...
  161. wierd noise. intake???
  162. please help, engine stall on automatic transmission
  163. Paint cracking on urethane kit HELP
  164. car shakes at high speeds
  165. engine problem ?
  166. Squeaking noise for about 5 minutes after startup?
  167. WTF!! Bottom of car is dented/cracked and protrudes into car
  168. Paint chipping on hood
  169. DIY on Radiator flush
  170. cold weather
  171. Car started like SH!T today?
  172. turn signals died
  173. Warrantee almost up, what to do
  174. cracking noise at 2k
  175. crazy idle? wtf?
  176. ummm... hot?
  177. light vibration from glove compartment area
  178. First Oil Change
  179. I'm stumped-and need help ** single POP when turning at low speeds
  180. Hole in rear bumper
  181. Tick Tick noise from the rear
  182. Tick tick noise from the rear
  183. Interesting thing happend last night...
  184. Bumper not flush with fenders
  185. Brakes Scraping
  186. Cold air intakes hate the cold!?
  187. Loud popping noise when revving @ high rpms
  188. stock suspension
  189. cd player used as piggy bank
  190. can't stand no vtec
  191. interior plastic faded by alcohol!
  192. people with autos
  193. wil my warranty cover this?
  194. New Engine, what kind do I get?
  195. bogg....
  196. parts
  197. Please Help
  198. Head gasket
  199. factory recommended maintenance list
  200. squeking sounds!!
  201. Im getting some horrible gas mileage....
  202. 2002 Civic EX brake pad (failed inspection)
  203. power steering is now fixed!
  204. spun rod bearing....
  205. Finally
  206. Would 4-dr oem sides and rear skirt fit on 2-dr?
  207. door locks
  208. Yeah so... car won't start (video)
  209. rough cold start in the moring
  210. section under bumper ripped off
  211. help side taillight bulbs not working
  212. High Pitched Belt sound .. am I overreacting??
  213. V-AFC2 Programming
  214. Car randomly won't start sometimes
  215. 02 Celica GT. 5speed Tranny prob.
  216. Adjust power steering asist?
  217. emblem problem
  218. struts........yea i need help
  219. another o2 simulator thread
  220. civic 92 dx,not much power
  221. Questions about this.
  222. Reset the Maint r'qrd light
  223. Reset Maintence Req'd Light
  224. slight hesitation at 50
  225. Starting problem
  226. double click window button
  227. Dash trim panels. Carbon, Brushed etc...
  228. Clutch noise
  229. flat repair: plug or patch
  230. windshield sprayers drip
  231. p0138 code ecu
  232. Help on ecu
  233. ODB II Codes
  234. 91 civic Help!
  235. Squeak when accelerating hard and shifting from 1st to 2nd
  236. Smack that Guage cluster!!!
  237. left front of car sags?
  238. brake problems at 30k?
  239. Can Working on your car yourself, void your warranty.
  240. Removing A/C, what belt replaces the old one?
  241. Noise when steering and breaking...
  242. RIP Driver-side eyelid
  243. Water draining back
  244. hmm i searched and no correct answer
  245. am i missing something?
  246. First Gear Won't Engage
  247. please help!!!! my car won't start!!!!
  248. cooling fan issue
  249. short shifter adapter
  250. Sounds like water stored in my engine bay when I accelerate slowly.
