To Those Who Have a Automatic Transmission, Please Do Me A Favor???
Old Jan 9, 2005
streetglower's Avatar
If you have a 01-05 civic coupe or sedan with automatic transmission, please go outside to your car and do me a quick favor. Put your car in reverse, neutral, and drive (With or without the car running) and tell me if you have slack in the shifter **** in those three gears. Basically can you move it back and forth in those 3 gears maybe like a bit less then 1/4 inch or so. Or tell me if when you are in those 3 gears, you can barely move the **** back and forth. I ask because I cant remember if mine was like that or not. I just did my oil pan and after reconnecting the shift cable, it seems like it wasnt like that before. Please do me this favor. I want to know if it is normal or not.
On mine, when in those 3 gears, I can put my hand on the **** and it will move back and forth like a 1/4 of an inch or so. Like there is too much free play.
Also when you put your car is the II on position, does the P and N light up, because my P and D light up?
Old Jan 9, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Its not difficult to putting it from reverse to neutral then to drive.. may take minimal force but it shouldnt be like butter.. oh and going from neutral into reverse requires u to put ur foot on the brake
oh and about moving it 1/4 inch.. i dont think mine does that
Old Jan 9, 2005
no not that, I mean put your car into reverse, now can you move the shifter **** back and forth a bit in reverse. Then put it in neutral, does it do the same thing, what about drive? When you are in drive, can you move the **** back and forth a bit while keeping it in drive.
Old Jan 9, 2005
Maybe I need to do the shift cable adjustment. That is also what I am thinking.
Old Jan 9, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
i can rock mine a little bit back inforth in each of those gears, but if im not careful it will just slip in the next slot, hope that helps
Old Jan 9, 2005
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
damn bro, sounds bad...mine doesn't do that, neither does my roommate's...i'd mos def check that cable....
Old Jan 9, 2005
Nameless's Avatar
TURTLEonK
my bad.. ya mines has a wee little bit of play in each gear.. hope you get everything straightened out!
Old Jan 10, 2005
well I see that some people have the same issue.
Now lets go to the next thing, turn your car on but dont start it, does the P and N indicator come on or the P and D indicator?
Old Jan 10, 2005
TheSmuggler's Avatar
P,D hmmmmmmm
Old Jan 10, 2005
_Viper_'s Avatar
No play in my 05 well a tiny bit but it shift very nice...Like with one finger
Old Jan 10, 2005
^^thats how mine is the play is like mabye 1 mm
knknif
Aug 4, 2015 06:11 PM
viperGTS
Jul 27, 2015 08:38 PM
Smokahontas123
Jul 22, 2015 10:07 PM
Q-Bert
Jul 19, 2015 09:09 PM
fatih717171
Jul 8, 2015 12:14 AM
