Idles at 400 and kinda sputters like its gonna die
Old Jan 15, 2005
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Hey guys it basically what the title is. I just installed my Random tech cat. and my Kamikaze headers and it ran great and idle at about 1gs. But after a while it started idleing at 400 and it bounces the tach...400-600-400-600 and you can hear it in the exhaust. Any clue whats up? I also shortened my throttle cable about 6 months ago with no problems until now.
Old Jan 15, 2005
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
its not the throttle cable.. if you screw that up it will only rev higher..
as to why its idling so low.. im not sure.. normal idle for our cars is about 700 once it warms up..
theres a lil screw somewhere that will adjust the idle.. but im not exactly sure where it is. ive never had look for it on a car less that 20 years old..
Old Jan 15, 2005
Reset the ecu and do the idle learn procedure. Then if that doesn't work read my sticky about idle adjust in vehicle probs forum.
Old Jan 16, 2005
jeffsta17's Avatar
alright I will try that...you just unplug the positive lead from the battery to do that right?
Old Jan 16, 2005
Um just open the fuse box next to the battery and pull out the FI ECU fuse for a few secs and put it back. Check the manual to see which one that is. Then let the car idle 10 mins without any accessories on and without pressing the gas. Oh and you need to fully warm up the car first before pulling the fuse.
Old Jan 16, 2005
jeffsta17's Avatar
Alright thanks
beneditti
Jan 15, 2016 12:31 PM
Nalmonte
Jun 9, 2015 12:30 PM
01civyv3
Jun 2, 2015 05:21 AM
mrcell24
May 19, 2015 10:02 AM
Ashley Farr
May 7, 2015 05:01 PM
