Loud popping noise when revving @ high rpms
Old Nov 22, 2004
ShadyImprtracer's Avatar
ShadyImprtracer is an unknown quantity at this point
Question Loud popping noise when revving @ high rpms
i tried looking all over the forum about this problem so dont get mad at me if this question has already been answered. i dont know if anyone else has a problem with this but sometimes when i rev it hard at either 1st or 2nd gear something in the engine bay pops really loud at random times. it scares the **** outta me when it happens. it only happens when i hit the gas pedal hard and i can feel it on the gas pedal maybe cuz its so much of a noise. almost sounds like a backfiring but it comes from the engine not the exhaust and i dont know if im messing sumthing up and if i should take it into the dealer. oh and it mainly happens when i rev it at high rpms and shift to 2nd right away...someone please help!
Old Nov 25, 2004
vtecpimp's Avatar
vtecpimp is an unknown quantity at this point
Yea, it's called valve overlap. Your valves aren't adjusted properly. You know how a 4 cycle motor works. You have SUCK ( AIR AND FUEL COME IN ) SQUISH ( YOUR PISTONS COMPRESSES THE MIX) BANG ( THE MIX IS IGNITED) BLOW ( IT IS RELEASED AS EXHUAST ) You have four valves per cylinder, two valves for intake, two valves for exhaust, when two are taking air in, the other two are close, when two are letting exhaust out, the intake valves should be closed. Valve overlapping occurs when your intak, or exhuast valves don't close all the way. Sounds like your intake valves on at least one cylinder are open when you are expelling exhuast and it is coming back up through your intake. Get this fixed soon.
Old Nov 26, 2004
can i take it to the dealership or do i have to take it to the mechanic?
Old Nov 28, 2004
vtecpimp's Avatar
I would let the dealership work on it, they specialize on Honda motors, and although you might pay more, i bthink they would do a better job.
Old Nov 29, 2004
well i would think i wouldnt pay anything because my car is still under warranty
Old Nov 30, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Uh. Valve overlap is part of all camshafts. Its not "bad." You just have to have the correct amount. Where are you located? I may be able to help you out.
Old Nov 30, 2004
southern cali...pomona/san dimas/ la verne area
lapchern
Jun 4, 2015 04:35 PM
civicns
May 8, 2015 09:49 PM
Aznnp77
Dec 13, 2001 04:03 PM
ModNewbieHELPME
Nov 30, 2001 06:13 PM
Sparty
Nov 15, 2001 04:55 PM
