please help, engine stall on automatic transmission
Old Dec 5, 2004
2002civicdx's Avatar
2002civicdx is an unknown quantity at this point
hi, i got a civic and the engine stalled yesterday.
I drove for about 20 meters, then stopped to open my garage door, two second after, I found there is no light on the panel, no mileage, noting, and the engine stopped, the key was at the ACC position
I then tried to start it again, the key can turn, but nothing happened.
tried again, still nothing
After that, I reinserted the key and everything is fine since then.
Anyone knows what causes the problem? The engine was not cold since I have used it 30 mins before.
I don't know much about car, hope something here could help
thanks a lot
Old Dec 9, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
On one of my old cars, this happened all the time.. now I don't know much about transmissions and their components and such, but the garage that I took it to said something about the torque converter solenoid.. I wasn't really paying attention and told them to fix whatever it was and then it worked great..
Old Dec 9, 2004
cordeez's Avatar
Member
cordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trustedcordeez should not be trusted
what ever you do, dont try to hit the clutch.
Old Dec 9, 2004
acurastype01's Avatar
w00t
acurastype01 is an unknown quantity at this point
you might need a new battery sir
Old Dec 11, 2004
thanks for your replys. In the case of torque converter solenoid, how much do they charge you to replace for it? Thanks
cruisers10
May 12, 2015 10:46 PM
crowtoo
May 11, 2015 06:50 PM
Flipg123
May 8, 2015 01:15 PM
alexkharden
Apr 23, 2015 07:13 PM
Sledge
Dec 7, 2001 12:09 PM
