PDA
View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Engine is dead
  2. Mechanical 02 sims are p!ssing me off
  3. Oil Low, Light On/Light Off, Safety Rev?
  4. Clutch problem help!!!
  5. Check engine light on
  6. Clicking noise when first turning on the car
  7. 2003 Honda Civic is throwing a code - P1298
  8. knocking or shakin in drivers side wheel well
  9. Headlight Aiming
  10. Catalytic Converter Question
  11. How do I replace my Fuel Filter?
  12. Problem FOUND!
  13. do i have everything?
  14. flapping noise, possibly from tranny?
  15. Aye Carumba! can YOU make sense of this?
  16. slow start
  17. Valve tapping noise?
  18. A/C fan, motor and etc..
  19. parking/corner light problem
  20. how do i replace a windshield wiper blade?
  21. Anyway I can take the key out without in parking gear in an auto?
  22. pully Bearing????
  23. 89 honda civic, pedal down, car shuts off
  24. How much for a new 2002 civc cluster?
  25. Did Honda screw up my car?
  26. Help with Passenger Window
  27. Road Noise...Can't figure it out...HELP
  28. Broken Upper Strut Bolt
  29. p1505
  30. My fcuking civic turns off by itself!!..
  31. backed into..
  32. VAFC2 on 99-00 si
  33. car is not doing well...
  34. A/C compressor??
  35. auto tranny problems... again!
  36. Back Again....
  37. Bad Engine Mount causing vibration?
  38. 02 civic strut bearing in a 01
  39. Idling up engine
  40. Replacement Key Immobilizer Programming
  41. noise when accelerating
  42. Intake Problem
  43. Continuous Metal Sound After Turning Off Hot Engine
  44. sister's car won't start
  45. Check this out!
  46. Bumper Fitment Question!!!!!!!!
  47. Maintainance Required Sign
  48. HX fuel economy
  49. HID Bulb...help
  50. NOS in an N/A Civic?
  51. cracked exhaust manifold
  52. Stalled...
  53. Can someone explainw hy this happens?
  54. Rear Defrost isn't working
  55. whats this called?
  56. engine ?
  57. Odd smell from the front of the car
  58. Melted Bumper
  59. Altenator removal
  60. My AC is not working....
  61. help please on airbag light asap
  62. loud noise coming from driver side engine
  63. throttle position sensor
  64. C.v. Axle
  65. 04 civic tranny grinding
  66. Car won't start
  67. Help..flickering battery light issue
  68. Anyone know if the shifter cable can be adjusted?
  69. Fan Blower issues
  70. 03 civic ex transmission.(already searched)
  71. did search need help
  72. Fan Switch?
  73. Air Filter Replacement
  74. i think i have a supercharger
  75. EACV Questions
  76. New Member about to do first fix-it...
  77. rebuild engine
  78. Signal lights and hazards go out.....
  79. Two Problems: Mirrors and Door Lock
  80. check engine light. no obvious problems.
  81. Civic 2002 diesel won't start
  82. Motor Mounts
  83. Exhaust!!!!!
  84. 67k miles and flashing cel light
  85. Tranny....Help!!!!!!!!!
  86. It won't start...bad starter?
  87. exaust...check engine?
  88. Power Window Switch Broken??
  89. Exhaust!!!!!
  90. Transmission Problem?
  91. Reverse not engaging sometimes
  92. Any one ever have...
  93. rattling when accelerating
  94. i need help...my speedometer stop...
  95. help ASAP civic wont start
  96. Alternator
  97. Sliced Windshield Fluid Box
  98. Idle Problems no its not when its cold start.
  99. defroster light wont illuminate
  100. driving problem...need help plsssss.
  101. Master Cluth Cylinder
  102. Gas Cut off early
  103. clutch and steering wheel vibration issue
  104. Car shaking upon braking
  105. passenger side power door lock problem
  106. Floor Getting Wet? Wtf
  107. slow passenger power window
  108. Whining Noise From Engine
  109. side airbag question (leather seat covers)
  110. Exhaust
  111. Din? Iso?
  112. kinda annoying
  113. When do I get new clutch?
  114. Help! Three OBD II Codes
  115. Seat Belt Bolt
  116. Speedometer "freeze"?
  117. Throttle body
  118. Bolt Question *Need help asap so I can buy and fix*
  119. M/T Weird symptom after long drive.
  120. water bubbling or gurgle sound?
  121. Problem with a 1997 toyota camry radiator flush
  122. No corner lights.
  123. passenger side blinker going way too fast
  124. help! car shaking/rattling and transmission light blinking
  125. HELP! My engine is smoking a little after I park...
  126. Clutch Clicking...
  127. exhaust problem, skunk 2 rattling on tranny
  128. Is my car overheating?
  129. Black piece on bottom of bumper
  130. 40K noises
  131. Clutch question
  132. 1 month old alternator, screwed!
  133. I'd like to know if I've gone crazy....
  134. OEM Spoiler nutz driving me nutz
  135. Service Question
  136. My car is dead!!!!!!!!
  137. Tranny bumps before car is warmed up?
  138. Chenk engine blinks
  139. OBDII Code Explanation?
  140. quick question
  141. VTEC question
  142. Confused about warning lights
  143. P1607 code on civic 2002
  144. Shifter rattles in 5th gear
  145. Light dimming while driving
  146. Steering wheel shakes
  147. a video from me, to you guys with your slippin tranny
  148. RSX won't start after Viper alarm install
  149. Idle Surge
  150. will it work? speed chip??
  151. Tranny slipping....
  152. Gurgling Sounds and Overheating
  153. Misfire On Cylinder 4?
  154. damn ticking and squealking noise!(and no its not the axles)
  155. Noob Question
  156. front bumper removal problem
  157. exhaust
  158. Dents/Dings
  159. Bad O2 Sensor at 59k miles? Legit?
  160. Shifter Lights Don't Illuminate!
  161. Need help with my 5spd!!
  162. Tail Lights Wont Come On
  163. gas gage
  164. Driver side door panel rattle
  165. Whats da cheapest a 5spd convtn shld be?
  166. CV Axle Problem, please advise.
  167. Stick will only go into park sometimes????????
  168. car is in safe/limp mode?
  169. Weird Noise 2005 Civic LX SE
  170. strange heat problem
  171. Aem Cold Air Installation!!! Help
  172. Sulfur smell
  173. Power Door Locks and Windows???...
  174. Problem with Headlights
  175. How to Tighten Door?
  176. honda civic 2000 ex brake lights aren't working. help
  177. Automatic Transmission..
  178. Annoying brake light...
  179. is it too late for the MIL eliminator?
  180. Transmission slip
  181. Blown Engine NOT on WARRANTY!?!
  182. rear speaker panel diagram ?
  183. Links that print out TSB's???
  184. rims are stuck!
  185. 2000 RPM's max.
  186. Steering Problem
  187. 99 civic si power locks?
  188. exhaust gasket question
  189. Cutting Down Exhaust Noise!!
  190. Heater Only Working While car is moving, Thought Mechanic fixed...
  191. CEL P1166 Code (Fuel Air Metering) (Primary HO2S (No. 1) Heater System Electrical)
  192. manual trans - shutter problem *UPDATE!!*
  193. caliper seized....?
  194. Brakes locked up???
  195. rattling noise when accelerating
  196. New auto tranny put in... having problems...
  197. hood rattle how to adjust?
  198. Electric clicking from ignition
  199. Falling mpg
  200. Wood pecker sound in the rear???
  201. Anyone know the effects of a crapped up heat shield?
  202. auto tranny.
  203. Bubbling Noise/Water rushing while braking!?
  204. All Lights And Gauges Went Off..but Car Still Running...
  205. Electrical Problems - 2001 EX
  206. high pitch sound
  207. Car just dies
  208. Crap!! my 01 ex auto tranny went out. only 66K too
  209. Something wrong with the beater!
  210. HELP! Major Tranny Problems
  211. Keyless Entry
  212. Gas Mileage intake related?
  213. Car stopping and vibrating.... :O
  214. Question about warming engine up
  215. Won't go into 1st gear
  216. Power lock doesn't open
  217. Ticking noise
  218. Tanny Problem...I searched
  219. Another Shot Tranny - Honda to the Rescue
  220. steering wheel viabration q's
  221. smoking exhaust?
  222. 1997 Civic not starting and cutting off
  223. Power Lock on Passenger Door is Now Broken.
  224. removing sticky shit????
  225. CLutch chatter?
  226. Would a B20 fit our cars?
  227. Code: P0401 Exhaust Gas Recirculation Flow Insufficient Detected
  228. HELP!!! Gas door wont open!!!
  229. SRS Light On, Alternator Voltage Too High, Accessory Socket Doesn't Work
  230. too much oil
  231. trans problem.
  232. Engine Problems
  233. Car chokes trying to go over 4000 rpms...
  234. Oil in Intake
  235. Bulges in rear roof
  236. Head lights (bulbs)
  237. reseting srs on 2002 ?
  238. 02 sensor causing bad gas mileage?
  239. Will warranty cover...a foggy headlight? Alignment?
  240. Front end/left side of car sits lower than right side (stock shocks/springs)?
  241. Transmission Slip....I know...this has been done to death
  242. Parking Brake Light always on...
  243. Car Spuddering! Need Help
  244. Adjusting idle and throttle cable
  245. HELP: 01' civic EX whinning noise ONLY on cold starts. 66K
  246. Exclamation warning light goes on and off!
  247. interesting electrical problem
  248. Another 'Engine Noise' Thread
  249. well im lost and the honda scanner didnt tell me nuthing
  250. 2003 Honda Civic Coupe LX - lots of issues
