02 sensor causing bad gas mileage?
Old Dec 8, 2005
teg91ls's Avatar
teg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trusted
i have a faulty 02 sensor and im only getting like 30 mpg with a mix a city and highway.. i would like to be getting 40+.. the last full tank i had i only did like 330-340 miles per tank.. will the 02 sensor do it?
Old Dec 8, 2005
streetglower's Avatar
if you have a faulty o2 sensor, your check engine light will be on.
Now I dont think you have a faulty 02 sensor. I get about 30 MPG with mostly all highway miles. ANd I also get about 330 to a tank. You arent going to get 40 MPG, maybe once in a good while, but its hard.
Now in general, yes a faulty 02 sensor can cause a decrease in mileage. If the sensor is reading too lean, the ecu will think you are getting too much air and will increase fuel. But again, a faulty one will usually throw a check engine light.
Old Dec 10, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
won't fouled or 'old' spark plugs cause a severe decrease in mpg?
sharp66
31
Jun 12, 2022 08:45 AM
bsmiley
Apr 27, 2015 01:27 PM
tylerginevan
Apr 27, 2015 12:29 PM
Thees1
Apr 14, 2015 08:23 AM
plastikman
Bolt-on Engine Performance
Dec 13, 2001 03:18 PM
