flapping noise, possibly from tranny?
Old Feb 1, 2006
ruffryde009's Avatar
ruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to all
alright well like the title says... I have a semi loud flapping type noise when the car is idle'ing (probably at higher RPM's but dont hear it due to the engine noise)
you can definately hear it from outside over the engine idle
I suspect is has something to do with the tranny because everytime I press the clutch down, the noise stops! has anyone had this problem?
what can it be?
I have not done any modification to my tranny nor engine for that fact (besides v2 intake)
Old Feb 3, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
you kno what it can be from??
the moron that made the 7th gen tranny
Old Feb 3, 2006
looks like the curse carries over to manual tranny too. it sounds like a throwout bearing in which case you might as well replace the entire clutch. Can anyone verify this?
Old Feb 3, 2006
ive also concluded its the throwout bearing from asking a few people and searching on the forum...
It was just a sudden thing from one day to another, and Ive been driving the car smoothly lately (preserving it for once it has turbo :-p)
Ill be getting a clutch installed soon hopefully thats the problem and nothing else also
thanks for the help though gearbox, sorry to hear bout your tranny
Old Feb 3, 2006
EM2jdm's Avatar
EM2jdm is an unknown quantity at this point
i had the same problem but after it replaced my clutch and flywheel the throwout bearing is loud as ever and that was replaced too so im going to take my car to honda
Old Feb 9, 2006
welll... just replaced the whole clutch (clutch kit)... still the same problem.. any ideas or suggestions?
Old Feb 9, 2006
Slow Gold's Avatar
I hope I offend you... Get mad
Slow Gold will become famous soon enoughSlow Gold will become famous soon enough
if u slowly push on the clutch can you feel the flapping in the pedal?
Old Feb 9, 2006
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
yes! i had this exact problem and in fact i hoping to get my car outta of the shop for this today!
hold on for more info....
edit: ok..
what you are describing sounds like the input shaft bearing. I have broken 2 of these bearings.
even when your car is in neutral, the input shaft will be spinning when the clutch is engaged. So it will be making the sound. But when you push the clutch in, the input shaft stops spinning so the noise goes away.
the throwout bearing is only spinning when you push the clutch pedal in. Otherwise, the bearing isnt spinning. So it couldnt make any noise unless the pedal is pressed in (which is the opposite of what you are describing)
To fix the input shaft bearing, you have to split the case on the tranny, remove the cluster gear, replace the $23 bearing, then re-assemble the tranny.
- turboegnr PM'ed me with this info
Old Feb 9, 2006
Slow Gold's Avatar
Well thats not that expensive. Its just a pain to split a trans if you've never done it.
Old Feb 9, 2006
ouch... well thanks... besides the noise... what problems can this bring?>
anyone want to write a DIY? lol
you would have to take the subframe out correct?
Old Feb 9, 2006
costing me about $1060 from the shop though the transmission casing was cracked and they also had to replace a motor mount
edit: not sure of what else it could cause...i did drive around like this for QUITE some time...like...months...i don't remember when it started...but at least like 6 months. (im a huge lagger lol)
Old Feb 9, 2006
holy crap...
sorry to hear about that
well ima be a sucker if i have to pay someone to install a $23
when my tranny was just open to install the clutch kit
can this install be done in a garage with the basic home tools sockets etc and jacks , jackstands?
Old Feb 9, 2006
EM2jdm's Avatar
i get the same noise from my transmission and i replaced the clutch,flywheel,throw-out bearing, took it to honda and they said it is the mainshaft bearing 675.00 for labor+parts
begogadashi
Jun 11, 2015 04:04 AM
MajTom
Jun 2, 2015 11:48 AM
bo_red
May 26, 2015 07:25 PM
dosmastr
May 5, 2015 12:19 PM
mazdamx3rs
Jan 20, 2002 07:38 PM
