2000 RPM's max.
Old Dec 19, 2005
ccspeedme's Avatar
ccspeedme is an unknown quantity at this point
2000 RPM's max.
Ok so i have a 2001 Honda Civic. some times win im driving it wont go past 2000rpm. win i unhook the car battery thin rehook it back up it works for a day or 2 thin go's back to runing a max of 2000rpm. any help wood save my day as i need to drive to atlanta in 3 days. thanks: unity one
Old Dec 19, 2005
PennyKnotOff's Avatar
auto?
Old Dec 19, 2005
ccspeedme's Avatar
yes it is
Old Dec 19, 2005
StealthCivic's Avatar
StealthCivic is an unknown quantity at this point
Utiliity one, tell them about the fuse man, and I hope some civic bro on here can help you out, give as many details as you can , auto trans, fuse going out 7.5 amp, etc. hopefully someone on here will know, there are some knowledgeable civic owners on here......
Old Dec 19, 2005
so is it just shifting at 2000rpms or staying at 2000rpms? are all the gears toping out at 2000rpms? pretty odd problem you got there. might be some kind of electrical short if it goes away when you unplug your battery.
Old Dec 19, 2005
ccspeedme's Avatar
thats what im thinking. i was thinking it mite b a fuse but im not finding a bad one now. unity one
Old Dec 19, 2005
ccspeedme's Avatar
shifting at 2000rpms as high as it will go.
Old Dec 19, 2005
so in 4th does it just top out at 2000rpms? like it won't go anywhere past it when you push the gas?
Old Dec 20, 2005
ccspeedme's Avatar
it wont go past 24 25 mph.
Old Dec 20, 2005
that's weird, my bet is its gonna be an electrical problem but i'm not sure where, problem a short interfering w/ the transmissions shift points somewhere. did you buy the civic used or are you the only owner?
Old Dec 20, 2005
ccspeedme's Avatar
used
Old Dec 20, 2005
streetglower's Avatar
is your check engine light on?
Also what fuse is blowing? Someone else said you keep having a fuse blow?
Old Dec 20, 2005
ccspeedme's Avatar
check engine light is on and that was a 7.5 interior light fuse.
Old Dec 20, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Your best bet is a $30 code reader from ebay. Find out what the code is, and then you should know what's really wrong.
Old Dec 20, 2005
your problem is occuring because of your check engine light. something is causing your vehicle to be in safe mode. Once you diagnosis why the check engine light is on, youtr problem will disappear.
Old Dec 20, 2005
ccspeedme's Avatar
im going down to honda tomarow to do that. thanks for your help. unity one
Old Dec 21, 2005
why not go to autozone, have them check the code for free, then let us know what the code is and we can help you. If your not under warranty, it will be cheaper.
Old Dec 21, 2005
yeah plus if you go to honda they might try and snake you for service you don't need. where do you live? i could read the code for you if your around the 909 socal area.
Old Dec 21, 2005
ccspeedme's Avatar
wint to autozone its code 1362 i live in charleston s.c
Old Dec 21, 2005
Unity one- there is a list of OBD II codes on here, I think under this topic mechanical problems/issues, check it out, it is a sticky
Old Dec 21, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
P1362 - Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) No Signal
P1362 - TDC Sensor No Signal
Old Dec 21, 2005
if you have a multimeter, I can guide you through on what to check if you want, just let me know.
Old Dec 29, 2005
ReD2k1's Avatar
ReD2k1 is an unknown quantity at this point
hey sounds like the same problem that has been with me for the past 5 months....i have a manual 2001 lx and ill be driving then all of a sudden it bogs down completely and wont pass 3000rpms...does your car backfire a lot when this happens? i got the code scanned and it came up as P0172 system too rich i had it a shop for about 2 weeks b/c honda would charge too much..they couldnt find the problem so i just dropped it off at honda and immediately they found that there is a faulty TDC sensor..cylinder heads, they said it might be more but i will keep posting...you might have the same problem...hope this helps
Old Dec 29, 2005
timbo's Avatar
timbo is an unknown quantity at this point
Try possibly checking your grounds. If you are expiriencing a voltage drop, ecu could be sensing this going into limp mode actuating rev limiter.
Old Dec 30, 2005
ReD2k1's Avatar
Honda found the problem and the car is working fine it was just the TDC sensor, and suprisingly the total was only $244 they did full diagnostics and everything...
Old Dec 30, 2005
should of went to autozone and told us the code. that sensor is only about $48. You could of saved yourself $200.
Old Dec 30, 2005
ReD2k1's Avatar
i had gone to autozone and they were the ones that told me the code was P0172 system too rich...but i just needed to get this fixed already cause it had been like 5 months this problem had plagued me, but thanks anyways
brennov8
Jul 13, 2015 12:57 PM
Jul 12, 2015 11:54 AM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
CivicsClass101
Jul 9, 2015 11:14 AM
