Car chokes trying to go over 4000 rpms...
Old Dec 9, 2005
SkiLLzSter's Avatar
illest ma f*cken member
i drive an automatic and everytime it tries to go over 4000 rpms it chokes...the check engine light goes on and off...when its on it chokes but when its not on it doesn't do that...only have 50000 miles on it...what could be the problem?
Old Dec 9, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
what is your trim? vp, dx, lx, ex, hx? if it's an ex or hx, you have vtec engagement problem.
Old Dec 9, 2005
SkiLLzSter's Avatar
i have a EX...oh man sounds serious...how do i fix that...i don't want to pay a shitload of money cuz i am broke as hell...
Old Dec 9, 2005
booba5185's Avatar
take it to autozone and have them run for codes, then go from there, anbd they check it for free.
Old Dec 9, 2005
booba5185's Avatar
but first, check your oil, it could be low oil pressure
Old Dec 9, 2005
SkiLLzSter's Avatar
could it be tranny oil??? cuz i haven't changed that yet ever since i got my car...it does look kinda low tho...
Old Dec 9, 2005
booba5185's Avatar
nope, normal engine oil, check that, if it's low it wont let vtec engage
Old Dec 9, 2005
SkiLLzSter's Avatar
ok thanks man...
Old Dec 9, 2005
booba5185's Avatar
does that mean you checked it?
Old Dec 9, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
dude list your mods and then lets try to work it out
Old Dec 9, 2005
tranny oil must be changed at least every 30k if not sooner. check the level of that oil and the regular oil, could be a whole list of things so you have to get that code read before i can tell you more.
Old Dec 9, 2005
SkiLLzSter's Avatar
i'll check it tomorrow...as for mods all i have is AEM short ram intake that installed 4 years ago and recently changed the air filter...with the old air filter light already came on so don't think thats the problem...thanks for helping out guys i'll check it tomorrow and see if i have enough oil...
Old Dec 9, 2005
also if the engine light is on, the ecu puts the car in safe mode so it doesn't rev past 4k. it could be any of the problem codes and still won't let you rev above the limit.
Old Dec 9, 2005
booba5185's Avatar
it could also be that you need to reset your ecu from the dirty filter....as gearbox said it could be running in safe mode from that....
Old Dec 10, 2005
streetglower's Avatar
OMG, do I have to explain this again. Here is the original thread.
http://www.7thgencivic.com/forums/sh...d.php?t=233373
As gearbox said, your car is in safe mode because your CHECK ENGINE LIGHT IS ON. weather it is on or flashing indicates a problem. stop trying to figure out whats wrong and quit checking anything. Get up and take your car to autozone or a shop and have them find out the trouble code that is stored. Once you diagnosis and fix that, your car will run normal again.
Better yet, open the hood and do a visual inspection, then go get the code. I have posted many of times before about this. I will explain it again, everything in the car works together. Sensors send info to the ECU, and based on that info, the ecu will determine what to send to the actuators and other components. It will also determine how the car runs. Now if one sensor sends a bad signal to the ECU, the ECU will send another bad signal to another component. the info it sends out is most of the times based on the signals it recieves. If it recieves good signals, it will send out good signals and the car will run correctly. If not, the car will run crappy or will still run fine, but the ECU will reconize a problem, and set a check engine light. And this is happening in your case.
FInd out the code and someone on here may help you diagnosis it. Those who have a manaul.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
tylerginevan
Apr 27, 2015 12:29 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
