slow passenger power window
Old Jan 8, 2006
mrbacardi's Avatar
mrbacardi is an unknown quantity at this point
ok i've done extensive searches and couldn't find anyone with the exact same problem as mine
the passenger power window rolls down slowly, very slowly, then stops maybe about 4 or 5 inches down, but with some addition hand force and pushing the button at the same time, it can get down all the way.
but...rolling it up works perfectly, so i don't think it's a faulty motor...any suggestions?
Old Jan 8, 2006
mine is starting to do that i think some parts may have dirt all over em thats making it go slow.
Old Jan 8, 2006
show0and2go's Avatar
show0and2go is an unknown quantity at this point
yeah mine is like at least 1 second slower than the driver side.
Old Jan 8, 2006
streetglower's Avatar
there is a TSB on this, mine had the same problem and I fixed it. Remove your door panel and check the run channel behind the door frame and make sure it is secure in the frame. Mine wasnt causing the window to roll up and down very slowly. The dealer replaced my regulator thinking that was the problem, but once I found the TSB, it fixed the problem.
http://www.geocities.com/pfeifferper...rontwindow.pdf
Old Jan 10, 2006
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
Hmmm, I had the same problem, I took it to the dealer and they fixed it. they told me the tracks had to be relubed. Take it in and see what they tell you.
Old Jan 10, 2006
thats pretty much what the TSB is. they readjust and lube the run channel.
Old Jan 10, 2006
mrbacardi's Avatar
actually i kinda got it working now, took out the door panel and all i did was put grease on the tracks and now goes down good just like the driver's side
however it still makes this annoying loud pitched squealing noise... ahhh whatever it works now.
Old Jan 10, 2006
Thrasher086's Avatar
Thrasher086 is an unknown quantity at this point
Make sure to check the weathering that it isn't getting stuck or fell off.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
timpan
May 18, 2015 07:06 AM
werdnahall
May 17, 2015 11:37 AM
got2kids
May 9, 2015 06:45 PM
