2001 Problems piling up. First turn single, then wiper, then windows...[solved]
Old May 26, 2015
ClapAlongChorus's Avatar
ClapAlongChorus is an unknown quantity at this point
So, this started a year or two ago. My turn signals would occasionally buzz occasionally as if a light was burnt out. They would then work again.
Suddenly, my wiper control was wonky. Wipers would start going on their own after bump in the road, or after nothing at all. Then my wipers wouldn't turn on for a day or two. Then the wipers would work predictably when off or on, but intermittent wiping was replaced with slow ineffective constant wiping when my control lever was in that position.
Then my power windows and turn signals stopped working, but they would work occasionally when my wipers were on.
There was no obvious fuse problems, so I took it in to a friend who said (correctly) that wiper motors were a problem for Honda and replaced it. Things worked better for a few weeks, then things got worse again. Currently my windshield wipers continue to behave poorly, but additionally they occasionally continue to run (or try to) if I leave the dash control lever even after turning the car on and removing the key.
I talked to my friend about the multiplex being an issue, but he replied that he didn't believe the '01 had a MCU. That doesn't jive with what I've seen in schematic diagrams. Is it time to go to a dealer? Is there something else that could be an issue.
Old Jun 13, 2015
re: 2001 Problems piling up. First turn single, then wiper, then windows...[solved]
So, this post didn't resonate with anyone, but it turns out going to the dealer was this best option.
It turned out to be an issue with the ground wiring for the dash. Some wiring had to be cleaned up is all. Still cost a couple hundred in labor due these wires being behind the washer fluid reservoir and requiring the dash to be disassembled... oh well.
Old Oct 28, 2021
Civicized07's Avatar
Civicized07 is an unknown quantity at this point
You couldve probably just re grounded the chassis to the body
nickD
Electrical
17
Oct 22, 2021 02:05 AM
Njr
Exterior
Jul 15, 2021 12:48 PM
What_It_Do
Jul 18, 2014 07:45 PM
mtroydaniel
Dec 4, 2013 01:12 PM
injencivic
May 19, 2003 07:51 PM
