exaust...check engine?
Old Jan 13, 2006
CJAS's Avatar
CJAS is an unknown quantity at this point
I did a custom exaust from front to back a little while ago. Ever since I've had the check engine light on... when it came on right away, i took it back to the shop and they replace the o2 sensor; it stayed off for a bit, then came back on permenantly.... its been on ever since.. i just figured my car didn't know what to do with the new setup (i have an 1.7 el), has anyone else had this problem? and if so, how'd you fix it?
thanks all
Old Jan 13, 2006
streetglower's Avatar
well first off do you still have the original cat converter on there? If you removed it and installed striaght piping, then the check engine light will come on cause you have no cataylst.
Old Jan 14, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
jus reset it. i think you have to hold the pin in the culster while yuor starting on the car
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
