Annoying brake light...
Old Dec 21, 2005
mrb420's Avatar
mrb420 is an unknown quantity at this point
For the last few days, my brake light indicator has been comming on whenever I stop. I checked the forum and inspected my fluid. It is right at the minimum line. Therefore, I guess i need to add some fluid. My question is:
Do I just add enough to go halfway between the min and max lines or do I fill it all the way up to max?
  • Does adding fluid seem like the solution to the brake light problem?
  • Can it be caused by worn rear drum brakes, meaning I need to replace the drum brakes?
Old Dec 21, 2005
djmota's Avatar
You can fill it either halfway or all the way to the max line, your choice.
adding fluid will make the light turn off.
A drop in the brake fluid level is either caused by a leak..(unlikely) or just worn brakes both front and back. , not necessarily worn out maybe just worn. It might be a good idea to check your front pad and rear shoe thicknesses just in case.
Old Dec 21, 2005
mrb420's Avatar
Well, I added the fluid and the light is gone. I'll have to monitor the level over the next few weeks and see if it changes. I just recently changed the front pads, but I have never touched the rear brakes. Maybe that's the problem...
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
cukaracha
Aug 27, 2015 02:02 AM
cncnut
Aug 23, 2015 01:25 PM
honda.lioness
Aug 6, 2015 11:58 AM
viperGTS
Jul 27, 2015 08:40 PM
