driving problem...need help plsssss.
Old Jan 9, 2006
CLeeNx04CiVic's Avatar
CLeeNx04CiVic has a little shameless behaviour in the past
right now i have no idea what is wrong...everytime i drive at high speeds the steering wheel vibrates but not all the time (its weird)...i rotated my tires, balanced all 4 tires to 0 (made sure it was on the dot), and did an alignment...there is nothing else i can think of that could be the problem...does anyone know what could it be?...TIA
Old Jan 9, 2006
^^btw...its a 2004 civic ex w/ about 31,000 miles if your wondering...
Old Jan 9, 2006
does it only vibrate at a certain speed? if you got a perfect balance, then it might be a bent rim if you went over potholes.
Old Jan 9, 2006
it vibrates only at high speeds...above 50 mph...what do u mean a bent rim?...a rim actually bent??...if it is then i dont have a bent rim...im on stock 2004 alloy wheels and tires 195/60/15 and its just pissing me off ...
Old Jan 9, 2006
well it could be bent and you wouldn't be able to see it. its not always obvious. but if its only shaking at certain speeds, its a balance issue. the weights like to fall off it seems on bad roads. i need to rebalance mine every few months especially if i drive upto chicago and drive on those crap roads.
Old Jan 12, 2006
thanks gearbox....ill take a look to see if i do have a bent rim but i doubt it...ill also rebalance them again at another shop...
Old Jan 12, 2006
make sure the shop knows how to do it. some places have no clue and it doesn't fix the problem. there is also a special way to do alloy wheels called an alloy balance.
Old Jan 13, 2006
Mutha Fn FBM 85's Avatar
Ride BMX
last time i had the same problem it was balancing.. above 50 it would shake.. and i had 2 bad tires lol.
Old Jan 13, 2006
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
it could also possibly be defective tires??
Old Jan 13, 2006
yup unevenly worn tires will vibrate. my firestones were terrible around 20k that i finally had to dump em. tread was almost gone too.
Old Jan 16, 2006
mb28's Avatar
mb28 is an unknown quantity at this point
Would a warp rotor cause any unusual vibration besides applying on the brakes. Like if your traveling at certain speeds like 75 - 80 then vibration goes away after 80?
Old Jan 17, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
i dont think rotors can cause can vibrations. i had mine on my car for about 50,000 miles and then i got them changed with the breaks.....never had a problem with any vibration. well i take that back. slamming your car can give alota suspention problems.
Old Jan 17, 2006
mb28's Avatar
Well the first time I had the tires rotated that is when the vibration started. So then I had it balanced same problem balanced again same problem again. They test drive the car and tell me that my vibration was from the rotor while braking duh I know that. I was then told that if they rebalance it again that I would be charged BUll*&%&%. Those guys told me that the rotor can couse vibration while driving bull%#&* again. I think it might be in the tires and they don't want to fess up to it. The tires I purchased from them were bridgestone turanza el400's back in Sept 05, tire size is 195/60/15.
Old Jan 17, 2006
gmcuajo's Avatar
gmcuajo can only hope to improve
A vibration can be caused for a lot of things. Check the tires. If you don't know much about cars, take it to a shop to check your entire suspension components; all the suspension components can cause vibration.
Rise the front of the vehicle and stand on jacks, move fast the tires side-to-side and up-and-down, if you see an abnnormal movement or hear a noise maybe it could be the bearings or steering linkages.
Check all the bushings, ball joints, the weight balance of the driver side axles, brake rotors, steering linkages, etc. Also check the rear parts.
Xuhme
21
Aug 7, 2023 03:40 PM
trellex
May 24, 2015 04:39 PM
sccarally
Texas
May 17, 2015 10:11 PM
tylerginevan
Apr 27, 2015 12:29 PM
smmahan
Apr 15, 2015 08:17 PM
