passenger side power door lock problem
Old Jan 8, 2006
mrbacardi's Avatar
mrbacardi is an unknown quantity at this point
ok, got this weird problem
i can't unlock my passenger side door no matter what (it's a 99 civic si)
keyfob doesn't unlock it, driver's side unlock button doesn't unlock. even when i manually try to unlock it, it moves, but it's like there's so much resistance it still goes back to the locked position
any help?? i've had this problem before, and disconnecting the battery fixed it, but now it's back and disconnecting the battery isn't fixing it.
Old Jan 8, 2006
streetglower's Avatar
sounds like the door lock actuator is dead.
Old Jan 8, 2006
mrbacardi's Avatar
well i fixed it, closed the driver's door, locked it with the key, unlocked it with the key, pressed the power lock unlock switch on the driver's door, and it opened. must be some programming issues
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
darwin-t
Apr 18, 2015 09:29 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
