Problem FOUND!
Old Feb 2, 2006
topnotch7gen's Avatar
JDM-Jonathan David Martin- I own everybody
topnotch7gen is on a distinguished road
Problem FOUND!
Couldn't understand why my car was acting up around 4000rpm, it was misfiring when I would get on it. I went to Checker Automotive and hooked up the obdII scanner and found out my #3 cylinder was misfiring so now I'm going to check the coil pack and spark plug and see what I can find. wish me luck.
It's been weeks of me trying to find a solution and now I atleast know. lol
thx to Gearbox for trying to help me out.
Old Feb 2, 2006
get a cheap ebay code reader for $30 and figure it out yourself. the mechanic that checked your car is an idiot. hids don't throw engine codes. electrical load detector is the system that turns the alternator on and off depending on when power is needed. you most likely have a bad ELD. i believe this is in the fuse box so just find a junkyard and buy the fuse box or just the eld part.
Old Feb 2, 2006
Yeah, but could my alternator be going? The ELD is actually under the fuse box, that little connection that plugs in. How do I tell if its bad?
thx
Old Feb 2, 2006
well there is an engine code for the eld. if the alternator dies, you will know it. the battery light on the gauge will turn on and you will be running on battery power (and not for long either).
Old Feb 5, 2006
BUMP> updated first post!
Old Feb 5, 2006
oh boy same happened to me and turned out to be a blown headgasket. coil pack is very unlikely but you can check the resistance with a multimeter and see if they're all about the same. otherwise check plugs. are you losing coolant? if your plugs are chalky it means there's burnt coolant on em.
Old Feb 6, 2006
welp no more misfiring, replaced the #3 spark plug and checked coil pack for cracks/etc...................doesn't misfire or cut out. IM THIS HAPPY
Old Feb 6, 2006
haha nice an easy fix for once.
Old Feb 6, 2006
haha no kidding. Still runnin good. thx
Old Feb 6, 2006
zen_master's Avatar
so, replacing #3 spark plug actually fixed ur cut out problem?
Old Feb 6, 2006
yeah, I went and scanned my car with the obdII reader, told me #3 cylinder was misfiring, replaced spark plug, checed coil pack, checked boots, no rips/tear/cracks etc........fixed the problem. I could of just had a faulty plug who knows. If you have a problem get the scanner hooked up and find out. Just make sure you read both types of codes.
There are TROUBLE CODES and there are PENDING CODES. Make sure you check both of them, thats where I messed up because I forgot to check the pending codes and that's where the prob was.
Old Jun 28, 2006
mclean987's Avatar
mclean987 is an unknown quantity at this point
my mechanic tried to check codes and he said it isnt giving any info at all does that mean i have a bad computer ? car was driving fine before engine swap, heres the post i did before
someome please help me i have a ex and swapped engine to another ex the car was driving fine for a few hours then the battery light came on, tachometer stopped working and temp gauge now the car starts but wont rev that high engine light is constantly on when i start it batter light stays on a while and then comes off tested the whole car and fuses and alternators and its charging i dont know what it could be? any suggestions would be greatly appreciated
Old Jun 29, 2006
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
Gearbox always to the rescue.
Old Jun 29, 2006
mclean987's Avatar
where is gearbox now when i need him
Blazz
Jun 4, 2015 01:04 AM
Blazz
May 25, 2015 10:56 PM
cruisers10
May 12, 2015 10:46 PM
hokiedad4
May 3, 2015 10:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
