- Heat only works while driving.
- gas milage
- wierd noise when i steer and gas??
- p0138 code ecu
- Door wont lock/unlock
- broken shifter
- slave cylinder broke
- My Back Wheel Locked Up
- please help out...
- Engine temperature gauge needle drop when heat turn on
- Steering does note return properly when returning from turns in both direction
- Steering Wheel Vibration Between 50-60MPH
- Think I may have a problem.
- Road Noise!!!!!!
- AT Slipping
- omg rattle season again!
- 4rd gear slipping?
- Stupid bumper clips won't come off!!
- brakes? metalish rattling,screechy sound
- Malfunction Lamp!!
- serious problem...
- takes longer to start up...colder weather perhaps?
- passenger window
- 1994 Honda Civic DX Fuse Diagram
- Getting this burn smell
- Trunk/Gas LEVER stuck...
- cleaning cylinder head?
- Strange problem...
- Hazard button doesn't light up
- will ex trans on lx work?
- Engine swap
- Transmission maybe??
- no oil leaks, no coolant drips...but overheating and low oil.
- Some weird noise, I can't figure out!
- Creaking Sound When Turning
- M/T - Shift Lever Difficult to Move/Hard Shifting
- I damaged my passenger DOOR HINGE!
- passenger window ??
- passenger axle nightmare !!!
- is my clutch on its way out?
- weird clukcing noise
- reved up and shifted at 7k (past redline)
- Anyone here done a o2 sensor yet?
- Side Spoilers keep peeling away.
- motor tapping
- Please help!!!!!
- Another 7th Gen with a ****ed up Tranny...
- Suspension / Brake Problem
- 5 speed HX problems.
- How does Honda diagnose SRS light issues?
- throttle body heater bypass
- nasty smell
- lower control arm help!!!
- Control Panel Woes
- transmission problem - $2,450 - wtf?
- Auto tran shift from P to D, feel 2 jolts?
- first issue with car. dealer response strange?
- Acura 1.6EL parking light bulb replacement
- SRS problem/complete frustration with 05 Civic
- AT downshifting when braking
- High RPM's
- E-Manage: VTEC Not Working
- Speedometer help.
- 01 Exhaust
- Injen SRI
- help with adjusting valves on a frankinstein
- Idle problems after DC sports tcs install
- Greddy EVO 2 Exhaust on a Sedan
- E-Brake problem
- Battery Light Blinking??
- replacement bulb for climate control knobs
- 2001 Ex / Flasher???
- issue with my car
- car surges
- Weird Sound After Running Into Deep Pothole
- Broken Motor Mount?
- Block Heater
- Steering Wheel No Longer Locks
- TCS Exhaust
- injen coal air intake grounding problem
- Having crazy headlight problem, maybe sombody knows??
- need help
- Speaker problems
- here is a question if anyone can help....
- weird shaking or idle...overheating too!!!!
- Shaking at 90kph
- secondary o2 sensor
- honda civic es3 rs seek for help
- Revo SS (broken??)
- Help taking out CENTER CONSULE on 04 EX
- Stuck Window on 2004 Civic?
- Tein Coilover Poping Noise.
- V-AFC II Problem
- Fuel Gauge/low fuel light
- Blinker problem when braking with headlights on?
- screeching sound coming from auto tranny.
- RPM jumping from 4-1000 wile driving
- cat. converter rattling
- Need Help!! Removing alternato
- Ame Short Ram Caused Check Engine
- stripped nut
- Help!! My car is knocking
- cold air coming in?
- Gauge lights out.
- I have no clue what happened...help?
- clutch problems
- trim on doors
- rainy day rattle
- Possible Tranny Prob. Please Help!!!!
- Possible Tranny/Clutch Problems
- screws under front bumper?
- anyone know how to check the timing belt or should i take it in?
- One common problem and one strange
- Does your gas gauge suck? Mine does.
- 01 vtec question
- air cleaner case trouble
- Terrible ride in NYC
- 2001 civic pulls to the left
- click sound when release clutch
- ebay fogs stopped working
- I read the sticky - srs light on after battery change
- Need Help! Removing Auto tranny.
- Cruise Control help please???
- Do I need shocks or struts?
- door open light?
- rattling glovebox
- Battery Light
- Clutch?
- Scanner can't read OBD 2 codes from my civic 2002
- Could it be the tranny? Already?
- engine noise
- broken shifter housing bolts ?!
- Transmission Trouble
- 2002 Civic, guage problems, please help!
- Can exhaust system do that?
- instrument cluster replacement potential problems
- Car Battery Dead For No Reason????
- went to get an alignment
- HUrricane wilma and HYDROLOCK
- tranny oil change help!! need help
- how do i check to see if water pump is bad?
- Maintenance light on continually at 85,000
- Check Engine Light Problem
- Long-term storage question. a bit of a crisis
- 01 ex brake squeak right front
- Odometer Repair Questions
- Air Conditioning Issue
- 94 civic cigarette lighter fuse ... which one?
- 5th gear vibration?
- dealer problems
- gauges stopped working
- T.p.s
- Alternator = Good, battery = good, But Battery still Drains
- Break Pedal Switch Pop/Click noise TSB
- idle problems...again
- Radio/ Defroster help
- Soot on exhaust tip
- overheat today...
- damm transmission
- windshield washer sensor
- Clutch Squeak!
- A/C problem
- Brake noise & A/C difference (EX, LX)
- Ball joints
- Sound when reversing
- Creeking noises got louder :S
- having a hell of a time gettin my nuespeed strut bar on
- Weird electrical issue. Help.
- Rear Defogger
- Need help... weird pinging sound
- Engine Gurgling
- trunk lock ... help!
- Steering Wheel Is Nutz0rz!
- 2001 Civic EX 2DR Replacing blower
- 01 civic stalls w/ out warning
- Car Alarm's not functioning
- Car going mad!!! Electrical issues....Help me!!
- Alt light question
- My car is overheating
- Cam Gear=Bad revving?
- General trans? question
- 2 problems
- blown about 4 fuses already
- I think I broke a motor mount..............
- weird radio problem
- Stock radio problem...
- problem with my hood...
- injectors
- p1298 code(electrical load detector circuit high imput) help please....
- 2001 Civic Speakers / Turn off AC / Keyless
- Civic sedan problems
- Projectors fogged up from rain
- does anyone know how to reset the maintence light?
- Problem with headlight
- clicking sound while turning and braking
- fuel milage
- best jacking point for rear of car?
- Revving weird
- Gasoline
- Engine hesitation when a/c is on (on an '04 EX Coupe)
- engine rusted, need some help
- Eng cuts out at 4k.
- HELP: transmission fluid leaking
- car shakes when i hit the brakes at high speeds
- Cig Lighter stopped working?? HELP!!
- Seat rocks around
- Fixing an exhaust leak
- ****ing SRS light is still on...
- A/C blowing warm. Fan not turning on.
- painted my turn lights with glass piant....bad news
- weird problem sometimes.
- there goes my power steering
- Trouble Starting
- This is how help should be asked.....HELP please
- Short ram problem
- Headlight problems (drivers side does not work) - No.. Not a recall, please help ASAP
- Cel
- 3rd gears goin
- Problem with trunk light and turning signal (fixed it 10/16)
- Mysterious Disappearing Gas
- Brake "knock" noise, exhaust "spitting" noise on '04 EX Coupe
- '02 Civic Si/SiR Typhoon Intake Problem
- why car wont start
- windows
- Keyless entry problems
- Auto tranny conversion
- WTF..dealership wont fix..
- HELP! can't stick it in.....and pull it out.
- water inside the passenger door
- Burning smell after driving? HELP!
- help please.. car won't start and late for school
- banged up my fender in the parking garage
- Help me figure this out!
- Help!!!!!!!
- knocking sounds
- Front passenger seat defective?
- cel is on again!!
- Noise from front passenger wheel??
- knocking noise
- Motor Mounts
- exhaust sounds louder in the rain...
- brake n clutch noises
- My Wheel Shakes
- Rear quarter panel
- car stalling...(amp power cable)
- Timing belt tensioner failure.
- Bored Throttle body
- Mirror Probs?
- no functioning gauges
