help please.. car won't start and late for school
Rep Power: 0 help please.. car won't start and late for school
I have no idea what is wrong with my car. This morning I was getting ready to go to school and I tried to start the car and it wouldn't. It wouldn't even crank. I was thinking it might be this theft deterrent device they installed, so I unplugged it and it still did nothing. I also checked the battery and it has a good charge.. So now I'm just lost.. Are the engine, battery, and oil light suppose to be on constantly in the ignition II position? Please help.. late for school already hahah
Rep Power: 429 yes the oil, battery and engine light will stay on with it in the II position. If the battery is ok, you may have a starting system problem. Or possibly a problem with the tranny range switch or clutch interlock switch or starter relay or the ignition switch, depending on if you have an auto or manaul tranny. an easy way to check the starting system is you can run a thick gauge wire from the battery to the "S" terminal of the starter and see if the starter turns the engine over. Make sure you disconnect the other wire at the "S" terminal. If it does crank or start, you have a wiring issue or bad range or clutch switch. If it still doesnt crank, then your starter is bad. or you have a wiring issue somewhere in that circuit.
Before you do anything, make sure everything is hooked up and there are nothing is missing.
Now when you turn the key to the II position, does the MIL go out after about 20 seconds?
Rep Power: 429 if the steering wheel was in the locked position, you wouldnt be able to get the car to the II position. Also the IAT may cause a no start situation but it shouldnt cause a no crank, no start situation. The IAT has nothing to do with the starting system. If it isnt cranking, then there is something wrong with starter or the components in that system.
Rep Power: 0 Well guys.. thank for all the help but I finally got it to start. After I wrote my plea for help, I went back outside and tried again. It started with some hesitation.. I just held the key in ignition III position till it cranked. But I still am wondering what could have been the problem.
Rep Power: 429 Well did it not crank the first time or did it crank and just not start? They are two seperate things.
You may just have a loose connection.
you can also check out this thread. It may be related to your problem.http://www.7thgencivic.com/forums/sh...car+wont+start
Retired suspension supermod.
Originally Posted by milk242
oh yea.. I drive a 2004 civic lx automatic.. these kinds of problems shouldn't occur on fairly new car.
I would check your installation and the fuses. My friend installed an alarm on his car and blew a main fuse.
I just burnt my tongue
Rep Power: 295 they 04 lx's have a tendancy to do that every once in a blue moon...mine did that once but after just stopping for a few seconds and taking the key out of the ignition, tried it again and it worked but it had trouble...my guess is on my car that since my driveway is at like a 60 degree angle and the gas was fairly empty so i had to get the fuel pump pickup to get some fuel to the engine before it would crank
usajags84
15
08-19-2015 03:12 AM
tylerginevan
04-27-2015 12:29 PM
SSMatey
04-13-2015 06:09 PM
