'02 Civic Si/SiR Typhoon Intake Problem
Old Oct 12, 2005
Koho65's Avatar
Koho65 is an unknown quantity at this point
I have a 2002 Civic SiR and over a year ago installed a K&N Typhoon intake system. After install, I noticed a very loud "poping" or backfiring originating from somewhere below the accelerator pedal. In fact I could feel it through the pedal itself. Honda Canada said get rid of the intake and K&N said have another shop check the problem. K&N said I had an leak somewhere that was allowing fresh air into the exhaust system and it was combusting. Two different Honda shops checked out the problem and could not figure out where the "pop" was coming from or why. Both said get rid of the intake.
Anyone else expereince a similar problem? Any solutions? Is the intake system worth the extra punch and sound at the possible expense of future engine problems?
Thanks,
"keep your stick on the ice"
Old Oct 14, 2005
swifty2k's Avatar
swifty2k is an unknown quantity at this point
I got a no-name (ractive) short ram from a local honda dealer..they installed it and when i first had it on, for the first couple weeks, it backfired 4 or 5 times..but its been on the better part of a month now, and it hasn't done it in a while...If its occuring quite often, I'd bring it to a local tuner shop with a garage...Im not sure what K&N has for warrenty, but theres obviously something wrong. Did you use any sort of lubricant or adheisive when you installed it, around the fittings?
Old Oct 15, 2005
Koho65's Avatar
I didn't use any lubricant around the fittings. Do you suggest one to use? Air may be slipping through these fitment points.
Old Oct 20, 2005
Koho65's Avatar
I didn't use any lubricant around the fittings. Do you suggest one to use? Air may be slipping through these fitment points?
Old Oct 20, 2005
stupidspoons's Avatar
stupidspoons is an unknown quantity at this point
when you installled the intake did you reset the ecu? because i know for the 01 i had to reset it.
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Hobby2K
Nov 9, 2001 04:08 PM
viper775
Nov 8, 2001 09:14 PM
skywalker
Nov 8, 2001 05:04 PM
vexxed82
Nov 6, 2001 08:00 PM
