Block Heater
Old Nov 14, 2005
Marin's Avatar
Marin is an unknown quantity at this point
Block Heater
I bought my 2001 EX or Canadian SI about 5 months ago and went to look for the block heater cable today and had no luck finding it. Does anyone know were abouts the cable plugs into the block? Thanks
Old Nov 14, 2005
DDragon7's Avatar
They dont have one, its an option installed at the dealer when the car was first purchased. Not sure if u can get one now if u want one. Also I was told that newer cars didnt need one.
Old Nov 14, 2005
tacheon's Avatar
tacheon is on a distinguished road
You need to buy and bolt one in. Very straight forward. Shouldn't cost you more than $60 if you install it yourself. Don't need it? Well, that depends how cold it gets where you are. If it gets below 25C, I'd seriously consider getting one.
Old Nov 15, 2005
Marin's Avatar
yeah im in edmonton alberta canada. It gets to below -33 sometimes and even colder with the wind chill.
Old Nov 15, 2005
Da1lyDr1ver's Avatar
i brought mine from the dealer 3 years ago and am too lazy to install it. i brought it for $60.
i dont get why the dealer doesnt sell them anymore?
Old Nov 15, 2005
rockhound124's Avatar
rockhound124 is an unknown quantity at this point
The heating element screws into a bolt hole above the oil filter. Not much room in there. I think you need like a 27mm socket yo remove it. Find some installation instructions on the net to see what it entails.
Old Nov 16, 2005
tacheon's Avatar
Any dealer should be able to order it. Otherwise, it's available from a ton of online retailers.
Old Nov 16, 2005
fiatdale's Avatar
fiatdale will become famous soon enoughfiatdale will become famous soon enough
I used the one on my pickup once in the 4 years Ive owned it, it was over a night of a -60F windchill. Truck started right up. Last year when we had -50 and I didnt use it, truck was VERY hard to start. Definitely worth it if you have easy access to plug it in, and its only like $60-$70
Old Nov 16, 2005
tacheon's Avatar
Just a finer point. Wind chill has no effect on something like a car. It is a measure of the physiological effects of wind on a human. The car will only achieve the minimum temperature, not the wind chill value.
Old Dec 9, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
I guess it saves your battery/ engine from wear and tear. I think I might get one this weekend because remote starting my car and letting it run for 5mins b4 i get in really uses a lot of gas
styles234
21
Nov 19, 2019 07:23 AM
JetsterDajet
52
May 8, 2016 12:11 AM
cferry7
Oct 3, 2015 04:33 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
hatch90
Sep 3, 2015 08:45 AM
