Ame Short Ram Caused Check Engine
Old Nov 10, 2005
Marin's Avatar
Marin is an unknown quantity at this point
Hi, i just installed my aem short ram intake and when i first fired the car up the check engine light came on. I shut the car off, diconnected the battery and started it up again and the light was gone. Is this normal? Everything is connected properly including the iat sensor. Any thoughts on when might have caused this? Could it be that the first time the engine just sensed too much air and wasnt used to it? It's off now but just wondering if anyone else had this problem ever. Thanks
Old Nov 10, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
nah the car has to do fuel remapping....
Old Nov 10, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
you were supposed to disconnect the battery when you were installing the intake anyway. but yes, your car is fine. before you do any more performance stuff, disconnect the battery so it can re-learn the fuel paremeters agian
Old Nov 10, 2005
shroomster's Avatar
don't narc on what I said...ninja-bitch I'ma kill you! *takes over thread with blatant attack of MajinB's ninjauality!*
Old Nov 10, 2005
MajinB's Avatar
Wtf?
Old Nov 10, 2005
Morton's Avatar
Make friends with your slow.
Morton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud ofMorton has much to be proud of
Wadup
It was the O2 sensor, MajinB is correct again!
Old Nov 10, 2005
shroomster's Avatar
Wtf?
I don't know....boredom?
Old Nov 10, 2005
saugashan's Avatar
This is not my batman glass!!
saugashan should not be trustedsaugashan should not be trustedsaugashan should not be trusted
i didnt disconnect my batery when i installed my short ram, and i got no porblems.. i though it jus takes longer for the car to figure out the new ****
dragonsblood
Apr 27, 2015 12:28 PM
dooner24
Apr 14, 2015 07:51 PM
ModNewbieHELPME
Nov 20, 2001 12:25 AM
HuDaThaN
Bolt-on Engine Performance
Nov 18, 2001 09:27 PM
1028CiViC
Nov 18, 2001 05:02 PM
