ebay fogs stopped working
Old Nov 6, 2005
dalaw's Avatar
Bone Stock!
I had my 01-03 ebay fogs installed back in April. Everything was working fine until last week when it suddenly stopped working. The indicator light on the button still works, and its now brighter than before. I checked the fog fuse and it was ok. There was this red wire coming out from the switch and the copper core was kinda exposed at one point. Could this cause the fog lights to not come on? Or could it be something else? How about that power relay thing? Thanks.
Old Nov 6, 2005
it could just be their pos switch. everyone always complains about it.
Old Nov 6, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
open wire. thats all. start cracking open the setup and see if you can find it
Old Nov 7, 2005
dalaw's Avatar
Bone Stock!
You mean to dig up all the wirings? I am not sure if i can do that cuz i didnt do the install myself.
Old Nov 7, 2005
MajinB's Avatar
ok, then go to the place and tell them to check it out. or get an ohm meter and do some investigating
Old Nov 8, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
here is the answer...EBAY fogs=crap...muahahaha
Old Nov 8, 2005
MajinB's Avatar
ok...lets see
Honda OEM fogs= 300 dollars
ebay OEM style fogs 30 dollars shipped!
Honda Installation charge=200 dollars
any shop install charge 50-70 bucks.
saving about 400 bucks- priceless...wait its worth 400 bucks!
Old Nov 8, 2005
Karumba's Avatar
Boredom causes changes ;)
All this talk about the wiring, etc etc ... Have you checked that the bulbs are still actually working???
Old Nov 8, 2005
PunkingCivic's Avatar
I need TP for my bunghole
what he said
Old Nov 8, 2005
dalaw's Avatar
Bone Stock!
bulbs look fine to me
Old Nov 8, 2005
shroomster's Avatar
aren't most of these small type of fog lights sealed beams?
Old Nov 8, 2005
MajinB's Avatar
wtf does that mean?^^^^
Old Nov 9, 2005
Notorious SI-G's Avatar
Notorious SI-G is an unknown quantity at this point
Check the ground wire for the fog light harness under the hood. That's why mine stopped working. Soldered it to a good ground that won't corrode and all has been good since.
Old Nov 9, 2005
dalaw's Avatar
Bone Stock!
Do you know how many ground wires there are? There is a grounding wire for the right fog light but none for the left one. There was never one for the left if i remember correctly.
Old Nov 11, 2005
Michalo187's Avatar
Abortion Survivor
You got what you payed for thats all i can say and good luck with your fogs
Old Nov 11, 2005
There is only one ground for both lights. You'll just have to follow the harness and see where the ground lug is bolted to the car. Most likely corroded. There is another ground lug inside the car where the harness plugs into the fuse panel.
Old Dec 4, 2005
schematicsskate's Avatar
schematicsskate will become famous soon enoughschematicsskate will become famous soon enough
i hope mine work
Old Dec 4, 2005
eddiechaps's Avatar
i love my morreale
turn them on & wiggle the plug to the bulb itself & see if it turns on. if it does leave ti that way & tape the wire to the harness liek that. it happened to my driverside foglight & i jsut taped the wire into the connector better & it works fine now.
crowtoo
May 11, 2015 06:50 PM
ORskier
May 3, 2015 12:54 PM
ashleymmackey
Apr 18, 2015 09:48 PM
CivicLX2001
Nov 16, 2001 06:33 PM
