3rd gears goin
Old Oct 14, 2005
bangemsmurf's Avatar
bangemsmurf has a little shameless behaviour in the past
3rd gears goin
hey my 3rd gear keeps poppin out wen im drivin wats wrong? any suggestions
Old Oct 15, 2005
Jrfish007's Avatar
It's a syncro. They go bad for shifting to fast, power shifting, or not using your clutch properly. I'm not saying you are a bad drivier, but this is generally what I see, and Honda has had weak 3rd gear syncro for along time on their cars. So lots of times they just go bad without any help, but not shifting properly can cause them to go bad even faster.
You should start saving for a replacement tranny and maybe even start shopping around. You can replace the sycro, but generally a tranny rebuild is more than just getting a junkyard tranny. If you can get a later model tranny, like '04 or '05, I hear they had a little beefier sycros. I personally would drive the car until it completely fail, in the mean time saving for a new tranny, then replace it. Even without a syncro, you can drive the car by rev matching the gears and engine.
Old Oct 16, 2005
2k1_Stockie's Avatar
2k1_Stockie is an unknown quantity at this point
Well, try changing the trans fluid. That might help out/delay the problem in the mean time, while you find a new tranny.
Old Oct 16, 2005
Michalo187's Avatar
Abortion Survivor
my third gear sounds like it grinds when i shift fast whats that caused by?
Old Oct 17, 2005
Jrfish007's Avatar
You are killing the sycnro on your 3rd gear. It takes time to let the syncro work, you're driving a civic with economy sycros, not an M3 with high end ones. When you shift fast you are not giving the sycro's enough time to "sync" the gear speeds and eating away your gear and putting undo stress on the sycro's.
Old Oct 17, 2005
Michalo187's Avatar
Abortion Survivor
so i should shift slower
Old Oct 18, 2005
Jrfish007's Avatar
yeah, that's what I tried to say, you just put it in compact and easy to understand form
Old Dec 12, 2005
nycnslored04's Avatar
nycnslored04 is an unknown quantity at this point
I just hit 54k miles in my '04 vp and I think my 3rd gear syncro is going. I can be creepin through town and it's fine, but the moment I get into a high rpm she grinds everytime. If I let the rpms drop a little bit befor I shift I'm fine as well. It only grinds in a hig rpm. Does my guess sound correct?
thanks chris
Solo Flow
Oct 4, 2015 07:52 AM
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
BBrosario
Sep 17, 2015 07:51 PM
