Maintenance light on continually at 85,000
Old Nov 1, 2005
StealthCivic's Avatar
StealthCivic is an unknown quantity at this point
What's up with my maintenance light on , staying on, at 85,000 miles on my car...It usually comes on flashing when I start my car every 10000 miles or so...I just turn it off ,but this time the maintenance light is on solid yellow ? Thanks.
Old Nov 1, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
that happens at other mileage as well... Mine happened at 10k I think... Then I wrecked the car around 20k it just means they want you to take it in and waste money on unneeded service. But if you want, go ahead and do it. But read your manual and it tells you how to shut the light off.
Old Nov 1, 2005
take it to the dealer asap for the $300 service. thats what the light is for.
Old Nov 2, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
prolly an 02 sensor, if you have an autozone near you they will usually scan for codes for free. If you plan on taking it to a dealership get it scanned before you go so you can tell if they are ripping you off. I have an obd2 scanner so I dont have to go farther than my shed.
Old Nov 2, 2005
Jrfish007's Avatar
Wrong light, that's the "check engine soon" light, this is the maintance light.
Old Nov 2, 2005
Jrfish007's Avatar
Fist of all, there is a sitcky for this (it's just a maintance reminder, basically to rotate your tires, it should start flashing every 8,000 miles then 2,000 miles after it comes on and stay on): http://www.7thgencivic.com/forums/sh...d.php?t=174951
Normaly we close these threads ASAP because there a ton of them and the solution is stickied, however it sounds like you have tried to reset it and it won't reset, in that case you really do have a problem. Let us know if you have tried to reset it or not, if you have and it still stays on, you have a problem and we'll try to address it if that is the case.
Old Nov 2, 2005
i have a solution for problems like this: electrical tape to put behind the place where the light is on the cluster.
Old Nov 2, 2005
Dakker's Avatar
Giggity Giggity
Dakker is an unknown quantity at this point
When are you supposed to get your timing belt changed?
Old Nov 2, 2005
Jrfish007's Avatar
Manual says 110,000 miles, if wait that long is up to you.
Old Nov 3, 2005
AlienX's Avatar
AlienX will become famous soon enough
MG !!! if that light is on, you really really need to go to the dealer RIGHT AWAY ! listen to gear, he's an expert in the maintenance light
Old Nov 4, 2005
thanks everybody, well, I turned the maintenance light off , like I always do, it was just different this time because it stayed on constant....
Oh well, so last night I go out to my car and it dies, strange clicking noises from within my dash, and then the lights fade, the car won't even turn over , dead, my friend comes over and we jump my car, we drive 25 minutes to my friends, just as we pull in my car begins to fad, lights fade and flicker my car coasts to a stop and dies again...so we all hang out and then try to jump my car again, well it won't charge, it stays very dead, only the window will roll up. so, we push start my 5 speed, rolling start in second gear and I pop the clutch - boom it starts, we drive home, my car is in my driveway dead again, I will push start it and go to autozone and get the battery and alternator tested. It is just weird a few days after that constant maintenance light stayed on ....coincidence??
Old Nov 4, 2005
C'mon man
C'mon gearbox, i read the sticky , after I made the post, why you say this to me man!!! you clown!!!
Old Nov 4, 2005
Jrfish007's Avatar
So after changing the battery, the light went off?
Old Nov 4, 2005
AlienX's Avatar
we warned you... and see what happened !!!!
Old Nov 6, 2005
I turned the maintenance light off before the battery went dead, now with a new battery my SRS light is on all the time!!! Man!!
Old Nov 6, 2005
AlienX's Avatar
you should have listened to that maintenance light
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
CarStuff
Dec 6, 2020 12:52 PM
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Caligirl
May 29, 2015 08:01 AM
