Radio/ Defroster help
Old Oct 29, 2005
Ratz-2004's Avatar
Ratz-2004 is an unknown quantity at this point
Question Radio/ Defroster help
Ok....When i turn the rear defrost on...My radio will go out.....Cd's work fine, but as far as listining to the radio....well i cant if the rear defrost is on....its just all static
Any know what i can do??? or at least why it does this???
Old Oct 30, 2005
is your antenna connected? check the connection and also if its an aftermarket deck you need to connect the power antenna wire.
Old Oct 30, 2005
Ratz-2004's Avatar
Yeah all the connections are there....behind the deck at least.....and the radio is comepletly fine and clear when i drive and use it.......but...When i turn that defrost button on...the radio reception just dies......not completly...but its very staticy.............
Munzy
21
Oct 7, 2015 07:48 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
BigG422
Sep 9, 2015 10:59 PM
