motor tapping
ok so last night i was driving along and i hit a massive water puddle. and of course my cold air intake sucked up water
. i shut the car off right away. got out disconected my intake and started up my car. at first it was tapping really bad. then the longer i let it sit and idle the worse it got.
how do i get rid of the rest of that tapping. i didnt look at my oil yet to see if theres water it it which im pretty sure there is gonna be. and i pretty sure i fouled out my plugs. is there anything else i need to change to make the tapping stop or what is your suggestions.
. i shut the car off right away. got out disconected my intake and started up my car. at first it was tapping really bad. then the longer i let it sit and idle the worse it got. how do i get rid of the rest of that tapping. i didnt look at my oil yet to see if theres water it it which im pretty sure there is gonna be. and i pretty sure i fouled out my plugs. is there anything else i need to change to make the tapping stop or what is your suggestions.
Originally Posted by ripspecv
is it possible i could have spun a bearing? cuz the valves look good.
huh? You checked the valves? You'll need to take the head off to check the valves. I would say bent valve too. Check the oil, you probably have water in it, but the damage is probably already done.
Originally Posted by djmota
could be a bent rod also. it depends on how much water was ingested.
I was thinking that, but I was tring to be optimistic
JLee93
Aug 21, 2015 05:44 PM
cizsak
Jul 21, 2015 03:39 PM
