Motor Swap
Motor Swap
So i blew my motor Friday. I'm in the process of pulling the motor out. I've got the head, i'm down to the block.
Would it be better to pull it out with the trans or without it?
And is it easier to pull out from the top or from the bottom?
I feel like i've bit off a bit more than i can chew but its too late to turn back now lol
The legs in the public bathroom stall
Re: Motor Swap
Generally speaking all FWD engines go out through the bottom. There are exceptions, but that is how it is usually done. Assuming you are referring to a 2000 civic I would drop it out the bottom since there is nothing under it like a large subframe. I would almost bet money on being able to find a youtube video that shows step by step how to remove the engine in a civic.
Re: Motor Swap
On my 2002, I was able to pull the engine/transmission assembly from the top with a hydraulic engine hoist. Just make sure everything is disconnected (fuel, electrical connections, vacuum hoses) prior to lifting it out, and work slow to make sure you don't pinch anything. Having a friend help you out is ideal, but I was able to do it solo
mistermenphis22
Jul 13, 2015 04:43 PM
