takes longer to start up...colder weather perhaps?
Old Nov 28, 2005
js89x's Avatar
js89x is an unknown quantity at this point
Here in Phoenix it's now getting colder (30s-40s at night), and I noticed for the last couple days I have to turn the ignition a bit longer before the car starts. I drive an 05 LX, so this is my first experience with Honda in colder weather. Do they normally take a bit longer to start when the temperature drops? The starter still sounds strong, but it just takes a couple seconds longer before the engine gets going.
Old Nov 28, 2005
allblack02's Avatar
allblack02 is an unknown quantity at this point
mine has done the same thing (02 lx) but it was only like 55 or somthing...
Old Nov 28, 2005
Npete7381's Avatar
Npete7381 is an unknown quantity at this point
Even though I've only had mine since August ('02 EX) we've already had several cold mornings here in MN, and mine has done that also. It always starts, just takes an extra second or two of cranking before it goes.
Old Nov 29, 2005
then there's something wrong. upgrade grounds, battery, make sure plugs are good and tight. Mine takes the same time to start whether its 100F or -10F and i got a leaky head gasket too. and 30-40? I would hardly call that cold.
Old Nov 29, 2005
doubledeuce2k2's Avatar
i don't think there's anything wrong. you drive the car at higher temps, shut it off, then you wake it up at cold temps. couple cranks, ECU figures out what's up, all is good. mine always does this in temp changes, once it adjusts after driving a tad, all is well.
Old Nov 29, 2005
MajinB's Avatar
Drunken Master-7thgen Ninja
um, i agree with gearbox.
possibilities
1. plugs- check them
2. plug wires- check those
3. dirty injectors- fuel injector cleaner is needed.
battery might be low. alternator might be frying.
Old Nov 29, 2005
Yoshiemaster's Avatar
Prince of Persia
Yoshiemaster will become famous soon enough
what is the battery's cold crank?
Old Nov 29, 2005
we have ignition coils not wires. cold crank around 440 but it says on the battery for sure. these motors are very precise as far as starting up. three turns and vroom should fire right up except in some rare case where there's a glitch or something. are you leaving the car in the ON position before actually starting the engine? if not, the fuel pressure won't be as high and it will take more turns to start.
Old Nov 29, 2005
Prince of Persia
yea mine started fine this past week when it was real cold. 03 civic ex. i'm gunna go with battery problem.
Old Nov 30, 2005
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
haha i have the same damn problem. it would start fine couple times but then sometimes it takes a bit longer than usual to start up. i dont know if it could b the battery but that might b the only thing that could b wrong cause i did accidently kill it when i left the headlight on for about 1hr or so.
Old Nov 30, 2005
Jrfish007's Avatar
I would say your battery is starting to die.
But exactly how long is it taking? Are we talking an extra second or 15 seconds?
Old Nov 30, 2005
maverickskat's Avatar
maverickskat is an unknown quantity at this point
My '02 civic did a similar thing for a while, slowly getting worse...eventually the battery just died (was a tad odd though considering the battery was only about 2 1/2 years old) ...got a new one...works completely fine now and no issues with cold morning starts. Might wanna check it out like the guys before me suggested
Old Nov 30, 2005
get optima yellowtop. then you can abuse it by listening to radio with car off, leave lights on, and the battery won't be affected like a stock one will. Even one discharge and stock battery will never be able to get full charge.
Old Nov 30, 2005
js89x's Avatar
Well I started turning the ignition to the ON position a few seconds before starting, and so far that seems to be working. Car starts up right away!
Old Nov 30, 2005
ah okay. not many people know that but it works. even 1-2secs is enough but some people leave it til the seatbelt stops beeping.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
jc33312
May 12, 2015 03:17 PM
Braun
Apr 23, 2015 09:03 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
gabrown2
Apr 11, 2015 08:22 PM
