Idle problems after DC sports tcs install
Yo, what's going on... So I installed my exhaust today, and everything seemed great, so I drove home. I cold started my car 4hr's later, and had trouble turning it over. After I started it the idle hopped around for a while and hung around 900 for a while but then dropped back to the normal 700 range. When I drive and then stop though, the idle hangs around 100 for about 5 seconds and then drops back to normal...
I reset the ecu, and went through the idle learn, and that didn't do a damn thing.
Is it an exhaust leak, do i have to readjust the idle manually, or is a sensor?...
wow, thanks for bearing with me.
interesting! cause my car is having problems too. but i'm still not clear what your car is doing. the rpm is going up and down by itself? its normal for the car to idle higher before it warms up.
ah okay mine is actually a misfire in the cylinder. yours sounds like something simple. did you do the throttle cable tightening diy? sticking rpms will happen if you did it too tight. but if the idle is fluctuating, it could be a bad tps or iac valve.
jakeconnor
May 5, 2015 07:30 AM
vtechcivic
Apr 21, 2015 06:58 PM
ej8
Apr 13, 2015 06:36 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
