Burning smell after driving? HELP!
Old Oct 10, 2005
chicohonda02's Avatar
Since 2002 Baby!
Question Burning smell after driving? HELP!
Hey are there some things to look out for, in order to tell if your radiator is pooping out on you or its calling for maint.?
when i drive I smell something burning, not sure if its radiator or something else.
Old Oct 10, 2005
streetglower's Avatar
what does the smell, smell like?
A radiator needs maintanence when it gets clogged and the engine overheats or the fluid inside has a low boiling point and a high freezing point and isnt holding heat. Or it is leaking.
Old Oct 10, 2005
Since 2002 Baby!
i guess kinda like plastic or something. someone pointed out to me that my radiator has burn marks and was recommneded to be repalced.
I ran over a plastic bag the other day, I'm thinking that maybe it got stuck and that's what's buring. Possible??
Probably I will go have it looked at tomorrow for service. Maybe that wil help.
Old Oct 10, 2005
Well If you ran over a bag and it smells like burning plastic, more then likely the bag got stuck to your exhaust pipe. I used to see that all the time when I worked at mercedes. Usually what they did was tear what they could off, then use a sander to sand the rest off. Otherwise, get as much as you can off and let the rest burn off on its own.
No need to take it in, just look underneath and see if the bag is stuck to the exhaust. If it is, follow what I recommended.
Old Oct 11, 2005
Since 2002 Baby!
In looked and ther seems to be little remains of the bag on the piping. But my car still smokes under the hoodish.
Old Oct 11, 2005
keitaro's Avatar
keitaro is an unknown quantity at this point
eve a little bit of a bag will smell for a long time, it also maybe wrapped around ur exhasut as well.
Old Oct 11, 2005
PunkingCivic's Avatar
I need TP for my bunghole
If you were leaking coolant; you would smell a sweet smell
Old Oct 11, 2005
Since 2002 Baby!
don't see any leaking. I'm getting it looked at on Thurs. We'll see i guess
Old Oct 11, 2005
where does the smoke come from under the hood?
Old Oct 13, 2005
Since 2002 Baby!
everything turned out fine. seems to be the bag on the exhaust that seems to be still burning off. thanks everyone for there help. This can be CLOSED NOW I GUESS.
Xuhme
21
Aug 7, 2023 03:40 PM
MyCivic
Electrical
Oct 28, 2021 11:06 PM
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
smmahan
Apr 15, 2015 08:17 PM
