HELP! can't stick it in.....and pull it out.
Old Oct 11, 2005
MYK1013's Avatar
Ok, this has been going on for a couple of days and it's starting to irritate the sh%t out of me. I'm having problems with my driver side key hole. It seems like theres something inside it that makes it hard to stick the key in and it also gets on the way when I'm pulling the key out (makingit harder to pull out) Has anyone had this problem?? Any ideas on what the problem could be?
Thanks in advance.
Old Oct 11, 2005
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
is your key bent?
have you squirted a lil wd40 in the keyhole?
you could also unbend a paperclip and use it to open the lil flap on the keyhole and look inside to see if maybe there is something in there..
if that dosent work.. i dunno.. get the keyless kit?
Old Oct 11, 2005
CraigW's Avatar
Try some graphite lube.
Old Oct 11, 2005
streetglower's Avatar
worst case senserio, just repalce the ignition switch.
Old Oct 11, 2005
Da1lyDr1ver's Avatar
Exactly right!!! go to an auto parts store and buy some graphite lube for your key hole. its not an actual grease but more of a powder. once you do this, your key will turn very smoothly.
Dont put WD-40 in the key hole
Old Oct 11, 2005
mugenman's Avatar
"mmmBAHHHH" - vtec y0
i have used my key maybe once twice on m ycar llol im so lazy
Old Oct 13, 2005
MYK1013's Avatar
thanks guys.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
crowtoo
May 11, 2015 06:50 PM
WhosYoDadday85
Nov 3, 2001 11:23 PM
