Timing belt tensioner failure.
Old Oct 6, 2005
mercer1's Avatar
mercer1 is an unknown quantity at this point
I had a timing belt tensioner fail at 100000 km. Resulted in 8 bent valves and piston damage.
Just wondering if anyone else had this problem.
Old Oct 6, 2005
streetglower's Avatar
sorry to hear that. Yea its almost a fact that valves will be bent with a timing belt failure, and yours resulted in the tensioner failing. was your car under warranty?
Its worse when the piston recieves damage. Looks like you are in for a new motor. Or a rebuid of the old one
Old Oct 6, 2005
PunkingCivic's Avatar
I need TP for my bunghole
what he said
your under 100,000 miles.
I say that should be covered under the powertrain warrenty.
Refer to your warrenty manual that shoould have got with the car.
Old Oct 7, 2005
mercer1's Avatar
update
Warranty covered. Rebuilt head, new pistons, tensioner, belt, rod bearings. Work is almost completed.
Old Oct 7, 2005
if they did all that, should have put in new main bearings.
mattdoc
Mar 14, 2017 12:10 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
