Trunk/Gas LEVER stuck...
I Queef > You
Due to crime I usually use my key to lock the trunk lever so that thieves can't open it from inside of my car. Well not too long ago I brought my car in for alignment and tire service and I notice a few days later the problem:
Even unlocked the lever (lift up for trunk and push down for gas) seemed stiff. I could open my trunk, but if I force it to go up all the way. I push down and open the gas door, but it has to be all the way down.
I don't know if it was the service guys that tried to open my trunk or not, but that's when I noticed the problem arise.
Question: How can I take apart that piece apart and mess around with it? I think it's the cable that is no longer attached. Thanks ahead of time.
I had the same problem... ended up I had some ice and crap in there and next time it got warm it was fine. Only did it once, which was wierd.
u guys have a rear tower bar cause when i installed mine the cable for the trunk/gas was acting the same way and i noticed the bar was laying right ontop of it. mayb that helps?
I Queef > You
Sep 3, 2015 07:01 PM
jdrolltide
Sep 1, 2015 06:54 PM
WaryDriver
Aug 22, 2015 06:50 PM
muttleytm
Jul 11, 2015 06:00 PM
