Handbrake Cable Disconnetion - 6th generation dx sedan
Old Jul 11, 2015
muttleytm's Avatar
muttleytm is an unknown quantity at this point
I have to remove a rear trailing arm completely. To do this I also need to disconnect the handbrake cable.
I see in a diagram that the cable for each side can be disconnected separately up where they come together, but I can't see where this is. I can follow the cable housings from the hubs towards the front the the car and they sort of disappear under a heat shield for the exhaust. When I look from underneath the car closer to the front of the car I don't see any sign of the cables.
Do I get at them from the inside by removing the console around the shifter and handbrake lever?
Old Jul 11, 2015
GolNat's Avatar
Prelude Owner
Re: Handbrake Cable Disconnetion - 6th generation dx sedan
Yes. Disconnect from the handbrake and push the grommets through the floor. I believe there is a bracket that you need to remove not sure where exactly it is though.
GotSiR
Jun 23, 2016 04:06 PM
dtdoyle
25
Aug 30, 2015 06:57 PM
Uan
Aug 23, 2015 03:03 AM
Curtchuk
Aug 5, 2015 02:14 PM
Dave1984
Jul 22, 2015 06:10 PM
