Shaking at 90kph
Shaking at 90kph
Hi,
I have a 2001 Civic Dx-G and been noticing some shaking happening on highway driving. it's got 80,000 km on it and it's stick.
on 5th gear, going at around 90kph, i notice the steering wheel shaking back and forth.
This only happens around 90kph. If i'm on 5th gear going at 80 and below or 100 and above , i don't have this problem.
i only notice this on highway driving since i don't drive at 90 kph on street roads.
Could it be a balancing issue?
my alignment seems fine, it hardly pulls when i let go off the steering wheel, but the slight pull that actually occurs could be from the bad highway.
what could my problem be?
Thanks guys
Thanks guys
if it's a balancing issue, why does it happen only around 90 km/h and not at any other times.
can you explain in detail what happens when the speed gets to 100 km/h and above; why faster or lower speeds make the problem not noticable or non existant.
its NOT alignment related, vibrations are caused from rotating parts...tire, wheel, rotor, axle.............. Most likely its a tire out of balance, out of round, or seperated
SolidHollow
15
Sep 13, 2015 11:18 AM
Mannimarco
Sep 7, 2015 10:01 PM
