- Sedan tail Help
- Service Bulliten request 97-009 FEB 00
- my civic=K.O.
- Heater doesn't work???
- Auto Shift Mechanism Problems
- Would you recommend your 7G civic?(esp 05HX)
- CEL On, Car Feelin' WEIRD!
- vtec malfuction
- Can anyone tell me whats wrong with my car????
- Guage Cluster Problem!
- Headlamps burning out
- I think my clutch is about to go?
- Hood Trim
- my civic is OVER cooling..
- headlight problem
- headlight bulb
- My Low Beams Dont Work.........
- Engine miss
- DIY question!
- Not sure exactly whats going on... Someone give me there opinion
- Window seal messed up
- Starting Problems
- Err, where is this oil comming from and why?
- 3rd gear grind on 02 ex coupe 5 spd *updated*
- spitting/crackling noise at high RPMS
- rust smell
- windows sticking
- rear defogger
- 2nd and reverse
- backfiring!
- no cat+cel on+driving=?
- headlight problem
- Seat belt buckle not always locking
- front windshield crack
- valves adjustment
- License plate frame screw bolt size?
- Idle problems - Advice?
- Tranny problem (auto)
- pasenger door tweeter rattle...help?
- riding the clutch question
- Wider Tires= Damaged Power steering???
- RSX seats install help needed...
- Emmissions light wont go off new 02 sensor
- car runs better before warm up?
- Acceleration/Braking
- TPS/Pedal position
- Projector install problem? Help please.
- Tran Problem on 01 Auto Civic ES
- Problem With Oil Pan
- Front noise
- The Continual Struggle of a Man and His Leaking Trunk
- Bad Gas Milage
- ticking noise
- Low pitch squeak when turning right at low speeds
- Door getting stuck!!
- Civic 2001 Electric Computer Diagram.
- Relays Behind Glove Compartment
- Civic Rocking while driving
- Squeek only when depressing brake
- Tranny problem??? please help
- umm. heLp?
- TSB's
- my car DOOR OPEN INDICATOR wont light
- how bad is this?
- Shifting into Reverse
- 1 small problem, 1 possible larger one:
- Can someone help me??
- Need a good fuel system cleaner?
- I will Replace my Tranny Will i need to....
- 12 volt outlet Question
- Noise From Lowering My 03 Civic-help!
- E-Brake
- Crap... Rain Got In My Car
- SRS light?WTF?
- Alternator and battery faq
- I'm retarded...
- Crackling sound from gas pedal when flooring car
- quick question about gasoline
- 02 Auto tranny slips
- Tranny Trouble...Which Moly grease in the Tranny
- Almost Dead Alternator
- need help on headers
- exhaust headers glowing
- Dent in my civic
- Neon affecting Radio
- Fender replacement
- WTF? No DC power...
- Rear tailights don't work
- how often..
- Steering wheel making noise
- noob question..wipers
- Low Idles, then stall
- new 04 ex coupe enigine noise?
- blown fuse
- Windshield Plastic Lining
- 03 Ex Tranny 3rd Gear Grinds! Help?
- 04CivicEXSedan AT Down Shifts Too Early??
- Either mechanical problems or there's a rabbit being killed in my engine bay
- SRS light...
- power steering ??
- Weird noises coming form my front right wheel
- Stereo Removal on 2004 Civic Sedan EX
- popping and clicking noises
- are my struts gone done?
- Window Issues
- my car wouldnt start tonight
- Broken Axel
- front grill with honda emblem ?
- 2nd gear grind on 04 ex coupe 5 spd
- Spoiler and brake lighting
- Front suspenison makes popping noise sound
- timing maybe?
- Paint Drips
- Scraped Rim - Help!
- 15a lights fuse keeps blowing
- ECU question.
- engine light on fuel mixture..
- any scrathes or dings?
- Engine Noise in 1st Gear - 2nd Gear Acceleration...
- Scratchy metallic sound at highway speeds (brakes or calipers?)
- Maintenance required light
- Maintenance Light *Blinks*?
- What's wrong with my speedometer?
- serious cooling issues
- Power door locks
- Need help...Engine spuddering, CEL on.
- Bye Bye Tranny
- broke down, turbo problem
- Rattling sounds from the back
- put the car in a ditch
- Totalled.... I think
- Big Problem...
- Auto Tranny Drain Plug
- Dealer tryin to screw me HELP!!!
- CEL after flywheel install
- Bulbs
- Warranty on car getting voided
- out of gas. fuel lid wont open.
- Well my radio is still screwed.....
- Water in trunk
- Car Idles at 1,100 RPM??
- How Many Times...
- fuel injector
- TSB's in CANADA ???
- Help! Exhaust Manifold
- is there a problem with 02 Manual Tranny?
- wtf?! whats wrong?! low revs
- balls in tires
- Help!!!! Alternator??? What do I do???
- Kinda Funny....
- puddle = squeaky belt?
- imobilizer problem
- Tie Rod End Spinning
- 7443 & 7440 bulb the same??
- cat back exhaust problem
- Transaxle hub nut rusted
- Calipers Clicking How To Fix??
- WTF!?!?!? No Rev limiter!?!?!?!?
- Sqeeky Clutch
- Car Battery's Acting Weird - Help!
- Slight Grind in Second Gear
- Wooshing sound from rear at low speeds
- Wipers gripping the windshield
- T/O Bearing shot
- clicking sound
- Skunk2 Muffler problems
- this was a good deal....I think
- Water in engine F**K
- Weird rattle - not sure where it's coming from???
- My serpentine belt squeals when car is running...
- stupid gas gauge...
- Battery problem or something else ??? HELP !!!
- Octane and fuel FAQ
- Alternator Gone
- noise in the hood
- engine problems?
- Civic 2004 EX max speed
- My Car Is Sreaming In Pain!
- WHAT THE F^&* IS WRONG WITH MY VIC??
- My Car Is F'd Up!
- Recirculation turns off when changing air control
- I need help finding
- Someone Please Tell me What This Shit Is?
- Engine stalling - 2001 Civic LX
- Help with Honda Wheel Locks
- Need help diagnosing sound
- Vertical Door HELP
- SRS light is on
- foggy light
- Heat shield
- my RPM's are fugged up
- clicking sound from front end when goin from drive to reverse
- 2002 Civic Guage Problems, Please help!
- Possible CAI problem???
- hot as hell and no ac
- new amp and now atenna sucks?
- System Draining Battery?
- Shifter light
- noise on right turns...
- Intake Problems
- Does Canada have a MAGUSON MOSS WARANTY ACT ???
- what does the seat sensor actually do?
- guages all wrong.
- Malfunction INDICATOR LAMP (stays on)
- CD player scrapping my cd's
- 2003 si engine knock?
- maintenance light
- CRACK on side LIP
- buzzing noise around alt.
- Honda Dealer Warranty Problem w/ neuspeed sports
- Problem with turn signal!!!
- brake light out but not burnt out
- Car Issues & The Dealer
- Replacing wheel bearing on 2001 Coupe EX
- Honda's BS
- top of windshield rubber gapping. anyone seen this?
- Fogged Headlights
- trunk latch/lock is broken
- Battery light blinking
- Throttle bracket problems? ANY IDEAS??
- water in the trunk!!!...
- check engine light on???
- brake squeaking noise
- Tranny Problem?
- nid feedback!!!!
- ashtray problem
- issue w/ my exhaust sound!!
- clear coat spray supposed to be like this??
- my stupid Honda
- wierd noice when turning
- Tranny Fluid. What brand?
- Bad Reception w/heater
- maintenence required light question
- Transmission - Jerky - Automatic - HELP!
- A/C Question
- front airbag light...
- dodge neon question
- Help me please!!!!!!
- Adjusting idle and throttle cable (pics)
- Rattle!!!
- 7th gen civics and their common problems...
- scraping noise
- What to do about Small Paint Chips on the Top of the Car?
- A/C Pressure
- need some help
- Engine whistling sound
- Angelina - Lovely Girl from Eastern Europe
- No radio power/dash illumination
- Things for better gas mileage?
- Running Way TOO Rich
