is there a problem with 02 Manual Tranny?
Old Sep 14, 2004
ncook21's Avatar
ncook21 is an unknown quantity at this point
I have a 2001 civic ex and my tranny was popping out of gear and it just kept doing it until my second gear is now finally completly gone. So i found a used tranny out of a 2002 civic ex and was wondering if they had the same problem with them and if it would bolt right up?
Old Sep 14, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
It's less likely, but they all have problems. You either get a good one, or not. It will fit, yes.
Old Sep 14, 2004
7Gnoob's Avatar
7Gnoob is an unknown quantity at this point
Why don't you take it to the dealer and bitch a bit until they fix your tranny. It's a problem they know about. I took my girlfriends civic in for the same problem and they rebuilt her tranny under warranty.
Old Sep 14, 2004
streetglower's Avatar
basically are you still under warranty? If you are, honda will fix the problem for free. Dont go buying another tranny unless you are out of warranty.
Old Sep 15, 2004
ncook21's Avatar
my car did not come with any warranties and i complained to honda and they had me call honda relations and they told me that they would fix it for free.....then i took it to the honda dealership and they started to work on it and found out i had a short throw shifter and they dropped me and didnt fix it for free so now i need to get it fixed with my own money
Old Sep 15, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
ALOT of people have the same problems with poping out of gear and sncro problems...
Good luck though
Old Sep 15, 2004
7Gnoob's Avatar
Damn thats tight. Any chance you can swap you're original linkage and try another dealership?? I't gonna be an expensive repair. Or try Honda relations again and explain that your short shifter is unrelated to the problem which they know about. Good luck.
Old Sep 17, 2004
sp3cialk's Avatar
sp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of lightsp3cialk is a glorious beacon of light
why didn't you remove it before you took it to the dealer?
Old Sep 17, 2004
lewal's Avatar
lewal has a spectacular aura aboutlewal has a spectacular aura aboutlewal has a spectacular aura about
I have been having problems with engaging in 1st gear... Like sometimes while stopped and with the clutch all the way down, the shifter still won't go into 1st. So i have to sit there and put it back into neutral, release and press down the clutch again and hope it engages.... 02 EX
Old Sep 17, 2004
DrivenConcepts's Avatar
Don't Listen To What Anyone Says, It's Ok To Be Jealous
DrivenConcepts should not be trusted
my tranny grinds really bad i was gonna do a flush and see if that helps. should i just take it to the dealer?? 02lx
Old Sep 17, 2004
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
that happens to me to, lol..i just shove it in cuz im like "oh **** the lights green!" probably not good for the car...but it savespeople from honking at me
Old Sep 17, 2004
WhiteRabbit's Avatar
alright, I have had this problem for about two years now, and I finally fixed the problem not 30 minutes ago, check it out:
your car may fall under honda's TSB. If it does, you can tell because itll be sticky going into gear. the problem will be more than intermittant, and you shouldnt have any problems getting the dealership to duplicate the problem.
However! there is a second possible cause, not covered by honda's TSB, can easily be caused by replacement bushings or replacement linkages or even modified stock shifter sticks. I called BS on honda for blaming my transmission problem on the stick as well.
So I bought a new stick so they would take it to honda of america. Install it, transmission works now. what the heck?
Well, it turns out that SOMEthing happened to the stick. I have no idea how it happened. But, when I pull the stick over to the left to put it into first or second gear, the stick doesnt stop becuase of the linkage bottoming out (like it should). What happens, is it hits the side of the plastic casing! So the left piston, the one that determines whether forward or rear motion puts you in first second, third fourth, or fifth reverse, could not fully engage!
Pulling to the right, and the stick didnt even coem close to hitting the side. stick stopped on its own. of course, it never popped out of fifth or reverse.
so what can you do to see if this is your problem? pull your center console. look at the stick itself, its surrounded by a square plstic border. your stick shouldnt hit that. if it does, show honda, tell them its unmodified and stock, and that they should pick up the $53 cost of a new piece.
if yours is modified, then youll have to foot the $53 bill.
20 minutes after you get the new part, your transmission problems may be over.
MajTom
Jun 2, 2015 11:48 AM
cruisers10
May 12, 2015 10:46 PM
lildoo
May 9, 2015 09:44 AM
dosmastr
May 5, 2015 12:19 PM
bsmiley
Apr 27, 2015 01:27 PM
