Engine miss
Old Oct 24, 2004
mkober's Avatar
mkober is an unknown quantity at this point
Angry Engine miss
I am restoring an 89 crx. It has developed a miss. I have replaced the plugs and wires. The injectors all sound good. I have checked the compression 2 cylinders at 70 lbs. one at 65lbs. and the one in question 55 lbs. I can take the wire off the distributor at low rpms and it still puffs but as I raise the rpms the wire off makes it worse. If it was a valve, wouldn't it get worse at higher rpm? Any suggestions, Thanks Mark
Old Oct 29, 2004
AdmireMyGr8ness's Avatar
SuperMod a.k.a ~AMG~
AdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond reputeAdmireMyGr8ness has a reputation beyond repute
Just because you haven't received any responses I'm going to move this so hopefully someone can help you....
P.S. Hope this was the right place to move it...
Old Oct 29, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Hmmm.... based on my own experience with older honda motors, I'd think about rebuilding that motor. Compression is usually real close between cylinders in a healthy engine. You can try checking the valve lash first. How many miles are on it?
Ninetyatecivic
May 9, 2015 07:48 PM
usajags84
Apr 10, 2015 09:54 PM
SoNiCcIvIc
Mar 11, 2002 03:37 PM
supercivic01
South
Nov 30, 2001 11:27 AM
viper775
Nov 8, 2001 01:58 PM
