new amp and now atenna sucks?
Old Aug 26, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Everysince Hifi Buys (Aka Tweeter) installed my new amp and box I pick up less stations on the radio?
Is that possible or am I crazy or what? Its really bugging me.
Old Aug 26, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Are you still using the stock Head Unit?
Old Aug 26, 2004
They probably forgot to plug in the antenna (stock deck), or connect the power antenna wire (aftermarket deck).
Old Aug 27, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
I was just relpacing my alpine amp tho...
Im running a Pioneer 6400 headunit, but they never did anything with the headunit... I just noticed it hardcore after the new JL Amp and box was installed tho?
Old Aug 27, 2004
Like Gearbox said, check and make sure the aftermarket unit has an antenna adapter plugged in. It might be loose during the install or they unplugged it and forgot to put it back.
Old Aug 27, 2004
manahoonie's Avatar
Check All Wire Connections That May Have Been Unplugged!
Old Aug 28, 2004
nikoscivicex's Avatar
www.8thgencivics.com
nikoscivicex is an unknown quantity at this point
Well when they install an amp, they still need to pull the head unit out to get to the rca outputs... See if they unhooked something they shouldnt have.
Old Aug 28, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
But i had an amp already installed before that one, I was just upgrading amps...
Old Apr 17, 2005
SlimmKidd's Avatar
SlimmKidd is an unknown quantity at this point
same problem I am having
Old Apr 17, 2005
is the power antenna wire connected to the harness?? I know we don't have one per say, but you need that connected for the rear window antenna to work.
Old Apr 17, 2005
zachgeyer's Avatar
maybe itz set just too pick up the ones that come in
Old Apr 18, 2005
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
just curious but do sedans have a power antenna wire on the deck?
i was reading a honda tsb that explained the difference between the coupe deck and the sedan one.
it said that the sedan deck w/ green led's also dont have the antenna power wire so therefore the sedan deck is not usable in a coupe.
Old Apr 18, 2005
MassMayhem's Avatar
MassMayhem is an unknown quantity at this point
Is it a 500/1? If it is, the problem is internal to the amp itself, The 500 is a Class D, and for some reason the internal circuits of the amp transmit a RF that can be picked up on AM especially, with some discernible distortion on FM as well. JL is aware of the problem, and is working on a fix as we speak. BTW, I have the same problem in my car.
Old Apr 18, 2005
OyD's Avatar
OyD
OyD is an unknown quantity at this point
I get no AM in my coupe and some FM is a bit shady. All connections are good. I have a Kenwood deck and MTX amp. I listen to 95% CDs so it doesn't really bother me but it would be nice if it worked properly
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
